- 24 Jun 2021
- Oxon
Well it's not a faulty cable, sigh.
NIC coming tomorrow. TX201
Turns out it has the same Realtek garbage inside and has the same issue.NIC coming tomorrow. TX201
TL-P12 FAN Spec:
Dimension:L120 mm x W120 mm x H25 mm
Rated Speed:2000 RPM±10% (MAX)
Noise Level:29.8 dBA
Air Flow:70.84 CFM (MAX)
Air Pressure:2.63 mm H2O (MAX)
Ampere:0.17 A
Connector:4 Pin (PWM Fan connector)
Bearing Type : S-FDB Bearing
This worked. No more weird noise, and still can't hear the fans. IIRC I increased the minimum speed from about 20% to about 30%.Changed the fan curves to have a higher minimum speed, only just done that so we'll see.
