UGREEN NASync Series - Owners Thread
Caporegime
18 Oct 2002
London
UGREEN are fairly new to the NAS space and with Synology making some questionable decision, it feels like they're on course to lose some market share to UGREEN, Ubiquiti (supposedly some new NAS solutions due) and other competitors. UGREEN currently offer the following NAS solutions:
  • NASync DXP2800 (2-bay)
  • NASync DXP4800 (4-bay)
  • NASync DXP4800+ (4-bay)
  • NASync DXP76800 Pro (6-bay)
  • NASync 8800+ (8-bay)
  • NASync DXP480T+ (4-slot)
I think the 2800 and 4800/+ are the most popular, particularly with the 4800+ coming with 10Gbe, a decent CPU for the price point and some AI features. I've recently bought one myself along with some shucked WD White 8TB in RAID5 and slowly learning what functionality NAS computers can offer (dockers, Home Assistant, HTPC/streaming, cloud backup).
UGREEN's OS is still in its early days and still has a lot of catching up compared to DSM but for a noob like me, it looks good and hopefully will improve over time. So I thought it would be good to start a thread and keep tips, guides and resources in one location. I'll update OP/thread in due time - thanks :).
Mini review of the 4800+
Impressive bit of kit. I think I managed to get it for ~£430 with TCB. The packaging was well constructed and it came with a couple of Cat7 cables, heatsink pads for nVMEs, screwdriver and screws and some keys to lock your drives - handy. The 4800+ comes with 1x8GB of RAM, upgradeable to 64GB (2 slots in total) - 8GB is fine for most and you only really need to add more if you're really into virtualisation/dockers. Setup was a breeze; plug into my network and use either a phone app or Windows/OSX app and start with the 'find my UGREEN device' setup. You can set your device to be completely local or allow access outside of your network (thus setup a UGREEN account) with a unique link/the app. UGREEN have a handy table explaining what data they collect if you're unsure about setting up an account with them, I believe they do not access or see your data.
Once you're in, you're greeted with a number of setup processed and mini next steps including setting up your storage pool (you have several RAID options, JBOD etc). The OS is really easy to use (Linux based) and has an app centre, control panel etc. So far I've setup a RAID5 array which took around 24 hours to process and optimise, this means if one of my drives fails - no data is lost (4 x 8TB, 8TB is used for redundancy - ending up with a little over 21TB of useable space) and I simply replace the broken drive and all is good. You have the option to add 2 x NVMe drives under the device as additional storage or as a cache drive to speed things up. Now that I have started copying files from my main rig to the NAS, my next steps are to setup an auto sync (1 way so any new RAW files I dump on my PC get backed up to the NAS) and figure out how to run my own version of Google Drive/Photos on it - supposedly done through an app called 'immich'. Overall - I'm very pleased but admittedly, I haven't done a whole lot.
The unit itself is very quiet and I can't hear it next to my UDM-SE, but it does ramp up a fair bit when under load (e.g. setting up my RAID5) but it was only an issue because of its proximity to our bedroom so noticeable at night.
One word of warning when it comes to YouTube videos for UGREEN NAS devices, especially the 4800+ - almost all of them are sponsored videos. I don't necessarily have an issue with them but my God, they're rife and they most all feel the same/surface level. I'll start listing some below with the first one being pretty good and he offers good advice and isn't sponsored.
Video guides/tips
Add Tailscale for immich (docker)
Docker compose -
copy the text below for your docker compose. Enter they key generated in Tailscale where shown (don't add a space after =). I believe it's senisitive about line indentation and it's not formatting properly below so will leave an image as well.
services:
tailscale:
container_name: tailscale
image: tailscale/tailscale:latest
restart: always
volumes:
- /dev/net/tun:/dev/net/tun
- ./lib:/var/lib/tailscale
environment:
- TS_AUTHKEY=# Fill in the generated key you saved previously
- TS_STATE_DIR=/var/lib/tailscale
- TS_ROUTES=
network_mode: host
privileged: true
immich server setup, just moving all my albums from OneDrive to it so all of my photos are in one cloud solution.
I am having issues with UGREEN's Sync & Backup. I'd already copied my files from PC to the NAS, then turned on Sync & Backup. It's taking forever and seemed to duplicate the folders so trying individual folders, still syncing. I've seen some comments saying it's not the best app and you may find better syncing solutions in docker.
I’m quite happy buying Chinese hardware, but there’s no way I’d be comfortable running Shenzen special software, especially on something that’s storing sensitive data.
Are there alternative open source OSs that’ll run on it?
One mod I'll be definitely doing is changing the main case fan (need to check BIOS first). When it's ~500 RPM, great and not audible but under load it will ramp up to 1000-1500 and becomes audible particularly under the stairs next to our bedroom.
It would only ramp up when under load but noticing it's at the higher RPM more and more, I do have a docker container running but the CPU usage is low and that fan rarely kicks in. @wigster - has yours shown this behaviour?
Noctua NF-A14 PWM seems the go-to replacement.
Edit - haha my bad, might have tagged the wrong person :p
No I don't have this behaviour because I don't own one lol still on the fence.
Struggling to get tailscale or Cloudflare working, found a good step by step guide for the former but once the project is deployed in docker - it just keeps restarting.
I’ve bought the dxp4800 plus and have put two 18tb exos in it. Running plain Debian 12 instead of the original OS. Really can’t beat the hardware for the cost!
  • Like
Reactions: KIA
What's Debian like? Admittedly I'm seeing more comments (including this thread :p) about allowing a Chinese made OS into your life. I'll look into alternatives but would like an OS that's fairly easy to use but has advanced features, docker support etc.
i have a 4800 and like it so far. just using 3 disks in JBOD and migrating over my plex content. I added 2x1 TB nvme drives and replaced the ram with a 48Gb stick. The app store is very limited but i installed docker then used mariushosting guides for a clatter of other things to try (donated 5 euro and get access to any of the guide specific setup files he uses - worth its weight in gold/time saved to me as a docker noob) currently have immich (very frustrating to try and import google photos takeout, still have't sorted that), stirlingpdf, heimdall, paperlessNX, nginx reverse proxy, nextcloud
plan is to workout tailscale install next
regarding the sync and backup, the ugos upodate the other day added snapshot facility for BTFRS drives - not sure if that is an alternative solution
didnt go for the + version as currently have no 10Gb network at all and it was cheaper. good excuse for a new box when this fills up more!
Thanks for the steer regarding the quieter fan - think i will try that as it is pretty noisy when it kicks in currently. I have also ordered some acoustic feet and will post back when these arrive and i fit them!
@encephalopathy - legend, thanks for the mariushosting tip. Keen to hear your tailscale installation, I've had to turn off my immich server as I can't access outside and it's not secure. I'll be doing my fan upgrade in a couple of weeks and have temporarily put tape across the front of the drive bays to stop the rattling. Pads or tape was another suggestion for the drive rails.
noctua fan arriving tomorrow and i fitted the wee isolation foot pads that seem to make bit of a difference - will stick the remaining 4 on my other NAS to see if it helps with it too!
Set of 8 AudioSerenity ISO-9H-23 Speaker Isolation Pads​
Just ordered the 4800 plus as my first NAS. On offer and there’s potentially 18% cashback available too taking it to sub £400 which seems reasonable enough.
Will order some more RAM, some NVMe and a fan in due course, and read up on RAID :cry:
Mainly just looking to backup photos, music and have more of my gaming libraries stored locally.
I ordered a DXP2800 which arrived today. Only need two bays and not bothered about RAID (everything is backed up elsewhere) so it's ideal for this use case. I have to say I'm rather impressed with it for £250.
The N100 is a great CPU for what it is - I've got a couple of N100 based systems already so know what to expect from it - really low power consumption and fair performance per watt. DXP2800 comes with 8GB of RAM and officially supports 16GB max but people have been reporting that 32GB works fine. Might bump it up to 32GB just because I can, as I will be running a couple of VMs on it too (N100 is fine for what they'll be doing).
Quite impressed with the build quality and the feature set is great too. OS seems to be pretty good, but it's also nice to be able to install any OS you want on there.
I've got a DXP4800 and I am very happy with it. Having said that I use it just as a NAS, everything else being handled by my Proxmox server.
It's currently idling at around 18w
Linux is Linux really. I didn’t need a whole setup as I was migrating from a VM I was passing through a bunch of disks to, to a standalone box so I was already running it pretty bare.
I use BTRFS as a file system on the drives and I’m using mergerfs to balance stuff between the main drives as it’s mainly media.
I did drop a pair of 2gb nvmes in for things like data and my photo library.
32GB Ram and 2x 1TB NVME ordered. I doubt the general sales this week will get any cheaper than they currently are.
Will keep my eye out for some decent sized HDD now and will grab a blu ray drive to start ripping the collection.
fitted the replacement noctua fan - bit of a pain - the screws holding the backplate of the NAS were super tight and i almost rounded 1 out - had to use a 8" thin screw driver, tap it with a hammer to seat it in and twisted for dear life. My short pencil sized mini screwdrivers wouldn't budge them at all. Noctua fan is a tiny bit deeper in profile than the stock one and when reinserting the fan securing screws i needed to push down quite hard to get the screws to bite and secure (the noctua fan has rubber fenders each corner - thin but a little compressible)
a 5 minute job ended up taking 25 mins!
Heard a few times it's quite hard to screw back in, glad you got it done. Any difference with the noise? I should be installing mine at the weekend.
