Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
I am not opening mine! If it isn't broken, don't fix it.
Ok and why’s that ? I’ve heard and seen people roll amps and it does make a significant difference.But OpAmps rolling makes no measurable difference!!!!! </asr>
I will open mine up this afternoon, delivery slot is 12:15 onwards
My personal experience with rolling op-amps is that the difference is minimal at best. Like, I would have to be AB testing back to back to think that I perceive anything. Blind testing if someone swapped them without telling me I wouldn't have a clue.
"people on there", I don't really go on those forums but if that's what some people say, ok .I like my Sparkos and to me they sound superb.That's the running joke, a large chunk of people on there don't think opamp rolling makes any difference because someone once did measurements and found the graphs didn't change much at all, even though you hear the difference with specific opemps.
I'm guessing that I'm the only person that uses bluetooth earbuds with noise cancelling and enjoys the cable free, freedom and weightless experience? I cannot stand wired headphones for gaming, very sweaty and it always aches my ears very quickly and the cable becomes quickly annoying
I do have some pretty hardcore speakers/amp/sub as well, but only tend to use it for online MP gaming and listening to music.
Earbuds or headphones wise?I haven’t found a good wireless set that is comfortable enough as my wired ones.
For gaming I bought the PC38. The Xbox headset was too small for me. It’s difficult to buy headphones blind and then only to find they don’t fit properly.
My Sony XM4 barely fits on my head at max extension.
I have a few sets of JBL's, 1 pair likes to work it's way out my ears, but the other works well, it's just luck of the draw for me as every pair of earphones/buds I've ever had required a different cup for my right ear
I cant stand the compression of headphones, and the heat over your ears and on the band, I end up very hot quick quickly haha!
Yeah it's such a nasty ache that they cause!I totally understand on the compression part, which is why I prefer headphones with extra large ear cups where it surrounds your ears. Why I dislike the Xbox one, and I am not really a big fan of the XM4, they are on the ear and they hurt after about 3hrs wearing them...but I have no choice on a plane. So on the plane I swap to earbuds after a while to give my ears some relief from pressure. But my ear buds are not ANC, they are wired, my ANC earbuds can't match the ANC in the Sony, I don't think any of them can.
At home I prefer headphones, I think or prefer IEM to be used on the go, I prefer big headphones at home.
But I actually, for general listening at my computer, I use the built i speaker from my Mac Mini. I don't need great audio watching LTT or Throttle House.
My hifi one can be openedI am not opening mine! If it isn't broken, don't fix it.
what keyboard is that you have and can the swicthes be replaced or just the keycaps?Thought mine just turned up but it was the new Edifier MR5:
Should be interesting to see what the line outputs from the DX5 II is like as well I guess and the MR5 also has balanced XLR and TRS inputs, which means i need to order more cables as I don't have enough for A/B testing.
