Yeah and I follow this guide and read all the comments:
www.reddit.com
This comment was especially useful. And you also need to bear in mind that memory overclock also affects undervolt ability, if on the edge of stability for example:
"I still believe there is a cap (no higher than 2827 at 0.89 and 0.895 are the only values found as it's hard coded in the GPU firmare. Even Bios flash doesn't circumvent that)."
I am not 100% on this but it seems to track with my experience. I have tested all sorts of voltages and clock speeds and 2827MHz at 0.895 is still the most efficient and stable. I did have to slightly lower memory OC from +2000 to keep the core clockspeed though. Rock solid now though and efficient.
