Dose anyone on the forum actually have a 9070/9070xt with Samsung memory?
Not sure what memory I have, but booting up Ghostrunner at 1440p max with RT, my memory settled/capped out 82 degrees with stock memory clocks (no changes to power limit, but -75 undervolt). Sapphire Pulse 9070XT ofc.Talking about the pulse, what is everyone's memory temperatures? The gamers nexus review said they were 90c?
Did and/sapphire update the drivers?
Nice I will give mine a under volt when it arrives, then I can retire my 3060ti aswell! It has served me wellSo I got a Pulse 9070 yesterday, some stuttering in DayZ but been tweaking stuff and its slowly getting better..jury still out on that one
A few quick benches, only using -40 UV and maxed the power limit atm..
EDIT.. Samsung Memory, just about hit 70c running Timespy
I scored 22 888 in Time Spy
AMD Ryzen 7 7800X3D, AMD Radeon RX 9070 x 1, 32768 MB, 64-bit Windows 11}www.3dmark.com
Result not found
www.3dmark.com
I scored 5 922 in Steel Nomad
A little longer (45mm longer) than my old trusty 3060 Ti but at least it fits in my Corsair 400C case with the 240mm radiator at the front
Amazed at the temps for 15% fan speed, seeing 48c - 52c in DayZ maxed out settings.. the 3060 Ti was in the mid 60's with lower game settings, really nice cooler on these especially in this weather!
@CAT-THE-FIFTH 3060 Ti finally retired!Sapphire Pulse 9070 - 08/07/2025
EDIT.. Samsung Memory, just about hit 70c running Timespy![]()
My launch Nitro has Hynix and temps are good. The Hynix OCs really well too, 2760 with fast timings, game stable.I've got a launch day Nitro waiting to go in a rig. Curious to see what that will come with.
Good to know - I'm waiting on mine, and also have the same PSU.Mine arrived today - Samsung also
Power wise no issues on my RM550x so far I did immediately undervolt though
Worse I've seen from wall so far is 420w
Had a minor wobble after adding negative offset on frequenxy rather than voltage earlier but could have been game (Oblivion remastered) had triangular artefacts. Tried FS2024, KCD 2, and Steel Nomad benchmark with no issuesGood to know - I'm waiting on mine, and also have the same PSU.
Nate
the two times I was getting driver timeouts and it plagued me it turned out to be my system ram settings/bios and the first time was the m.2Hi folks,
I've had my Asrock Steel Legend 9070 XT since launch and I'm generally very happy with it. However, I'm getting driver timeouts when playing Forza Horizon 4 with my mates and it's driving me nuts!
Does anyone have a genuine cure for this? I've tried pretty well all the suggestions I've found online for this issue, which it seems has plagued AMD for years! I've got to admit that I'm beginning to regret buying AMD, never had issues like this with my previous nVidia cards.
Please help! Cheers
Hynix appears ever so slightly faster, Samsung appears to be pretty significantly cooler.I just sold my launch-day Nitro that has been sitting on a shelf since I got my 5090 in April. Didn't even check what mem chips it had.
Which are preferred this round, Samsung or Hynix?
It could be a number of things. Texture cache being one of them. If it’s on steam go into settings and remove. One of the guys on here had to resort to reinstalling windows. Might be worth getting a spare drive and installing windows to see if it’s that. I would also verify the game and do a repair. It might be worth going into event manager to see if you have any critical errors. What power supply do you have and what’s its age. Does it do it in other games.Hi folks,
Please help! Cheers
Thanks for the reply Gamethe two times I was getting driver timeouts and it plagued me it turned out to be my system ram settings/bios and the first time was the m.2
did you do a fresh install of windows when you changed cards ?
Thanks for the suggestions eeii.It could be a number of things. Texture cache being one of them. If it’s on steam go into settings and remove. One of the guys on here had to resort to reinstalling windows. Might be worth getting a spare drive and installing windows to see if it’s that. I would also verify the game and do a repair. It might be worth going into event manager to see if you have any critical errors. What power supply do you have and what’s its age. Does it do it in other games.
