You weren't in sexy edit mode. Tap the three dots at the top right of the reply box and make sure the square brackets below are black.Thanks, got them now, they were all greyed out.
Is someone working on the back end at the moment?
I think you answered your own questionJust logged on and I was greeted by was a message saying the forums were being updated and currently unavailable.
I think you answered your own question![]()
I wasn't being sarky, sorry you felt that you way. You genuinely did answer your own question.But hey, you carry on with the sarcasm if that's what you need to feel superior.
It is.
I've been having a mix of lag, and cloudflare errorsThe forums are feeling quite sluggish just now. Is the lack of heat affecting the hamsters?
Started getting Cloudflare verification check when opening the forum page.
No real problem as the forums still work ok after clicking the check box, just wondering if this is happening to anyone else.
Ah, that's fair enough.We have been hit by relentless bot swarms recently so have some additional checking to stop them crashing the forums.
What bowser/OS?I see the issue of threads still opening at the last posted image, not your last read post still hasn’t been squashed.
Chrome on Pixel 8 Pro, Safari on iPad too.What bowser/OS?
I've not noticed it on Chrome/Windows apart from when it's a thread i've not been in for IIRC 30 days (when it defaults to sending me to the first post).
Happens all the time in this one for me: https://forums.overclockers.co.uk/threads/summer-transfer-window-26-27.19012208/I see the issue of threads still opening at the last posted image, not your last read post still hasn’t been squashed.
It's probably a filter list causing the issue. The way I would diagnose it would be to disable all the lists, then enable the ones you had enabled one-by-one until the problem occurs again. Be aware that it might be more than list.Not quite forum related, but while I'm here, I think the cookie banner on the main website breaks the site if you're running ublock origin lite or ghostery or something similar.
Search breaks, the tabs for product specs break etc.
I don't have this on any other website. I've tried disabling certain plugins, but still to no avail, it means I have to use an incognito window every time I want to browse the shop, which is every annoying. I've not tried to troubleshoot in detail. It's been like this for quite a long time now.
Windows 11 Chrome for sure. I can check if it's mac too though if need be.
