- 6 Aug 2004
- Norwich
If it has the same innards as the RG577, it'll be able to handle a whole bunch too.Liking the look of the RG477m so far. 4.7 inch metal case Anbernic.
I too am interested in the 477m but cant see it besting my Odin 2 mini pro.
Damn, no OLED or analogue triggers!?I was too as I would like an ultimate 4:3 device, but the rumoured price seems very high for what is a less performant soc, no oled and no analogue triggers.
I got to the point id tried about 15 devices and just wanted something that 'worked' and was solid. Odin 2 mini pro was expensive, but worth it. I paid around £290 delivered.It is looking pricy. I don't think i could drop £200 on it no matter how good it is
This. Just be aware copying files can be (is) very annoying from windows (exfat) to linux (ext4)Least tweaking / switch power = (assuming you don't want it for portability, or pocketability to be more precise) Steam Deck OLED.
Also gives you a million other things too.
I followed this guide yesterday and it was dead easy, no need to connect external drives to the deck after this.This. Just be aware copying files can be (is) very annoying from windows (exfat) to linux (ext4)
That was one of the reasons I decided to give Android a try.
When I first got my Steam deck there was a program that did something similar to this and worked for the most part but remember copying files the speed was reduced or fluctuated massively. e.g. from 90MB sec write speed down to 1MB/sec then back up and all over.I followed this guide yesterday and it was dead easy, no need to connect external drives to the deck after this.
I'm not massively sure what some of the specs mean, but not sure I like the stick positions. Assuming it's as powerful as I assume it is, you'll be wanting to run PS2 / GC / Android games on there, and so be using the stick a lot.
Russ has a review up already.I'm not massively sure what some of the specs mean, but not sure I like the stick positions. Assuming it's as powerful as I assume it is, you'll be wanting to run PS2 / GC / Android games on there, and so be using the stick a lot.
If you have a look at the video I posted above, that method will mount both your Steam Deck main SSD and the SD card as drive letters in Windows so you can explore all the folders on the Deck via windows explorer just like any other folder. You can then drag and drop roms, mods, or whatever to and from the deck directly into the folders. You don't need to use winpinator as an intermediary and move files on the actual deck in desktop mode. You don't even need to put the deck in desktop mode to mount the drives. It is a doddle really.I do wish the windows > Linux file sharing was easier.
However I now just use winpinator to wirelessly move any files I need from PC > Steam deck - mostly roms TBH. If I need anything else, I just do it all directly on the SD itself. Got myself a little bluetooth keboard / mouse all in 1 thing, use desktop mode, firefox, explorer etc. and it's dead easy really.
I believe the 477m (4:3 & quite powerful) is mainly aimed at ps2 & gc emulation.I dunno what it is about the 4:3 screens that are just so much more appealing to me than a widescreen one. I only have an RG351MP which I've mainly used to play SNES and a bit of PS1, but the RG477M looks like a direct successor with the same design but bigger and better specs, so I can't say it hasn't piqued my interest.
Having said that, the non-staggered shoulder buttons aren't great, the flat back design isn't that comfortable, and the sticks positioned at the bottom are awkward to use. The start/select buttons moved to the bottom right is also a downgrade, and front firing speakers would be way better.
