- 30 Sep 2005
What resolution do you run at?
Pimax Crystal 2880x2800 (4312x5100)x2 = 43.98m pixels
so basically over 5 4K monitors
Yeah, you're definitely going to be GPU bottlenecked with that resolutionPimax Crystal 2880x2800 (4312x5100)x2 = 43.98m pixels
so basically over 5 4K monitors![]()
Thanks for that, its defo made my mind up to stick with what i have for the time being, would be more than happy with those results and good to know i could go up to a 5080 @1440p, yes i will loose a few fps compared to the 9800x3d but not nowhere near as big a difference as i thought.Hardware unboxed did a perfect video for you today. Cruix of it is at 1440 high setting or above your ok with the 5800x3d unless your running above a 5080.
Exactly what i have at the moment, although my 4070 isnt the ti or super....just a standard 4070I've got a Nvidia 4070 with my 5800x3d.
I'm not sure whether to upgrade to AM5 and new GPU in a GPU generation or two.
Or try to skip AM5 alltogether and try and get a 5090 2nd hand at some point.
I went from a 2070S to a 9070xt - I couldn't be happier to be honest, it's great for 4k and VR for me (Mostly flight sims and the odd FPS)2070 Super currently. I was planning on getting a 5070-tier card, but the launch being a bit of a shambles made me just sit it out. I'm keeping an eye out for the upcoming 5070 Super to see how that pans out.
It's just about keeping up with the current games I play, but I definitely do feel the age sometimes.
Despite am extremely happy with my 9060XT - Wished I could get the 9070XT instead but my budget wouldn't allow it at this time. Have no plans to change my 5800x3D at all. Mostly play Flight simsI went from a 2070S to a 9070xt - I couldn't be happier to be honest, it's great for 4k and VR for me (Mostly flight sims and the odd FPS)
Also seeing no reason to migrate from the 5800x3d - they seem like the perfect combo.
Nate
Will probably be looking for a 5070ti when i finally upgrade gpu so should all be good
Thanks again
Thanks for letting me know, im not in a rush to upgrade anything now as i can play battlefield 6 ( well the beta anyway ) at high frames @1440p...over 120fpsThe Super variants are due to launch this year, I doubt they'll be much faster in raw performance (5-10%, there's no cores to unlock so it's really just clockspeed improvements), but are rumoured to come with more VRAM.
The 5070S will have 18gb, the 5070tiS 24gb, assuming said rumours are true.
Depending on price I'll be eyeballing a 5070tiS myself.
so will wait to see what the new versions of the cards are like.This is what I'm waiting for.The Super variants are due to launch this year, I doubt they'll be much faster in raw performance (5-10%, there's no cores to unlock so it's really just clockspeed improvements), but are rumoured to come with more VRAM.
