- 11 Sep 2020
- London
My 5090 FE (undervolted) is very similar or maybe even slightly quieter in terms of coil whine than my 4090 FE. I would just buy it and try it for yourself. You can always return it within 14 days. I switched from a Corsair RM850x PSU (850w was plenty when the 5090 is undervolted) to an NZXT C1500 PSU and the coil whine reduced very slightly as well.How does it compare to the 4090FE?
I’m close to buying the 5090FE but if reports are it’s a lot worse I may go for something different.
The 4090 I had was on the limit of what I can tolerate.
