Man of Honour
- 21 Nov 2004
Love this thing. Fully stocked now
I've had The Gauntlet drying towel by The Rag Company for a while now. It's worked wonders.I could do with a new drying towel and wash mitt, any suggestions chaps?
So of course after washing the car yesterday we had a brief shower of dusty rain. Lovely.
https://www.cleanyourcar.co.uk/stoner-invisible-glass is what I recommend. I've always used this stuff, it's quite good. No streaks. As with any cleaner, make sure to use a microfibre cloth to wipe with the cleaner and then dry the glass with the dry side or a separate dry cloth.Can anyone recommend some good glass cleaner (for windscreen etc), everything I try usually cleans OK but when it rains and you use the wipers its terrible.
I normally end up using the wipes but that's a littles wasteful and they never seem to last long or dry out in seconds.
Bilt hamber is amazingCan anyone recommend some good glass cleaner (for windscreen etc), everything I try usually cleans OK but when it rains and you use the wipers its terrible.
Came into the thread, answered VR and then forgot to post my own question
So I've been an idiot and bought a white car. Mechanically it's fine but it doesn't appear to have ever been washed right so I want to do a full decontamination
Can I DIY it or should I just pay a professional?
You can DIY easily, if you got a lot of time
Clean and protect with this: https://soft99store.co.uk/collectio...roducts/glaco-dx-glaco-glass-compound-roll-on
Top up with this: https://soft99store.co.uk/collectio...-glass-cleaning-agent-and-liquid-wiper-400-ml
EDIT: This is also very good, as recommended by Forensic Detailing: https://www.amazon.co.uk/Nilco-Professional-Nilglass-Smear-Free-Cleaner/dp/B003TFXK78/
