Or almost existed - Voodoo VoltsUsed to exist, went into a 5 inch drive bay.
The old 8 pins didn't need fixing, they worked perfectly.
You know what they say...
Well, just in case you don't realise, PCI-E connecters will melt if not connected properly too.
But, no clicks for tech websites for reporting those. PCI-E is old news.
Instantaneous spikes shouldn't give parts enough time to heat up though. This is one of the odd ones in my view.Interesting... we don't tend to see melted 12vhpwr below 400W and, in theory, the 9070XT should sit well below that level. That said, I note we've discussed on here before than the 9070XT seems to have some pretty spiky transients - on a par with the old Nvidia 3000-series. Wonder if that was a factor here?
I have yet to see one of the adapters that come with the cards melt on the 8-pin side. -Even though the 8-pin connectors, and the opportunities to melt, outnumber the 12-pin connector 3 to 1 or even 4 to 1.Well, just in case you don't realise, PCI-E connecters will melt if not connected properly too.
I find it odd that all these builders are capable of properly connecting multiple 8-pin connectors on these adapters yet somehow lose the skill to plug in a connector the moment they get to that one single 12-pin connector on the adapter.
I'm sure 8 pin connectors can melt, but it seems to take a LOT more effort to make it happen.
The adapters are a great resource for comparing and contrasting the reliability of the two connectors since the same individual is most likely responsible for connecting both types of connectors on each adapter.
I think the issue is that the 12-pin is engineered within an inch of its life and the 8 pins have a much larger safety margin.
If we tried to use up all the headroom on the 8-pins and only put one or two 8 pins on one side (for 600w applications...I know they don't work that way now), the adapters would probably start failing on the 8-pin side too.
Critical thinking in action and this is dead right, where there are adapters in use it is never the 8 pin side that's melted, always the 12 pin side, they are the weak link in the chain.
This connector really needs to go. Should have been scrapped by the 5000 series.
On the 12V-high-failure adapters that come packaged with the cards?I've seen plenty of melted PCI-E connectors![]()
If they are hell-bent on using this connector for asthetics, then they need the GPU's to be able to track each pair's current, and shut down when something is out of whack.Agreed, it would be really shocking to see it return on their next gen cards given all these issues. Can’t believe they used it on the 5 series.
It can't be that hard to do, if the Asus Astral can monitor amps on each pin then why in the hell is this not a basic feature as standard that's built in by Nvidia?, the cards already cost a stupid amount of money, so price isn't an excuse, at least if the amps on one pin start getting far too high then the card can simply cut power in the worst case scenario, or like a car go into the equivalent of limp mode where it keeps the card at only using 2D clocks until you fix the issue so the power draw stays low, but the card is still usable.If they are hell-bent on using this connector for asthetics, then they need the GPU's to be able to track each pair's current, and shut down when something is out of whack.
They just have a tiny safety margin. If everything is perfect on the construction and installation of the cable, then it's fine. If any little thing is out of tolerance from the manufacturing process or installation, it is NOT fine.is there still an inherent weakness in these connectors?
It didn't just return it came with Nvidia's reassurance that they won't melt again as the problem has been fixed. Sure it has, as witnessed.Agreed, it would be really shocking to see it return on their next gen cards given all these issues. Can’t believe they used it on the 5 series.
