- 20 Jun 2023
- uk
I use a 20 something year old Sony theatre system for surround via optical.
It's a bit clunky but works fine.
So those edifiers are active, right? there's a speaker cable that comes from the right speaker to go to the left? How have you wired things up to the amp? Via what connections?So change of plan, I've moved the PS5 downstairs and will be going with a 2.1 set up for my PC gaming
I bought the Fosi MC351 and connected to my PC via optical
My Edifier R1280DB's are connected to the L and R channels
I set the Fosi to OPT but I only get sound from the R channel. I can only presume its something to do with the L not knowing what input to use for sound - any ideas? Have I missed something in the setup?
I might use the Fosi amp in my son’s room. Connect it to the tv via optical and run some speakers off it that I have that I know will workYou've bought an AMP for active speakers, does your motherboard or soundcard have an optical out? Just use that, send the Fosi amp back for a refund.
this was my thinking as well. I was just trying to figure out if he's been sending voltage to the output in the right speaker, if he's wired it up like that. Hopefully the right (main) speaker is ok, since it was likely taking voltage through the left speaker amp output connectors. My next step would have been to attach optical as you said, and wire the left speaker back into the right.You've bought an AMP for active speakers, does your motherboard or soundcard have an optical out? Just use that, send the Fosi amp back for a refund.
I believe they have a built in DAC of decent quality so you don't need anything special other than data passthrough to the end product (aka the speakers) which optical will provide.
Quick question, I have the Edifier speakers connected to my PC by optical. The sub then connects into the back of the speakers
Is this the best set up or using my Soundblaster Z SE soundcard, should I utilise the front and sub ports on that?
I only ask because when I'm in the creative app, i change it to 2.1 but when i test the config, i hear nothing with the optical set up
