I know! I am looking for oneNeeds a double bass pedal...
Yeah get working on learning and when you're ready, yeah a starter pedal like that can last you a while whilst you learn and improve in double bass too.I know! I am looking for one.
Need to learn how to play first though!
I was just thinking of treating myself to https://www.thomann.co.uk/millenium_pd699.htm, ok its entry level but thats really all I need at present.
Honestly, they're fine for reaching high speeds - you don't need to spend hundreds. Sure, you'll get more feel and a smooth swing from higher models but it's not a shower stopper. I know someone playing on a 20 year old Mapex thing and he's playing 180bpm with ease, meanwhile I'm stuck at 140bpm with my Iron Cobra!I know! I am looking for one.
I've been playing for about 4 weeks, and am happy I can bash along with something at 90bpm. I think it'll work just fineHonestly, they're fine for reaching high speeds - you don't need to spend hundreds. Sure, you'll get more feel and a smooth swing from higher models but it's not a shower stopper. I know someone playing on a 20 year old Mapex thing and he's playing 180bpm with ease, meanwhile I'm stuck at 140bpm with my Iron Cobra!
Perhaps I dont need a double pedal but a lot of the music I like certainly uses it - not saying its the right way to go.I've been playing in all sorts of bands since 1970 including many hard rock bands and my drummers have never needed a double bass drum pedal.
When you look at the Gods like John Bonham, Ian Paice, Keith Moon etc they never needed them.
Fair enough if you want to emulate Dave Lombardo or Neil Peart.
* Ian Paice many decades later admitted that he used another bass drum belonging to Keith Moon when he did the intro for Fireball.
Funnily enough many 1000s of drummers recreated the opening drumming with one pedal![]()
Trust me, your brain will be the blocker the more you advance with thisI also think it would actually help with limb independence, though I think I have a headstart on that anyway.
Oh, sure, but I play the Piano and Organ which require a significant amount of limb independence so hoping the mechanical side will be taken care of!Trust me, your brain will be the blocker the more you advance with this![]()
It does help, piano player since age 5 here!Oh, sure, but I play the Piano and Organ which require a significant amount of limb independence so hoping the mechanical side will be taken care of!
To rich for my blood. I'll stick to my cheapo one for a long while I think!I have a Pearl Eliminator chain drives - both single and double![]()
Personally I'd get two singles and an additional kick pad/trigger unit. Pretty much the sole reason double pedals exist is due to the size real kick drums take up - with edrums that isn't a concern so treat yourself to the "real thing".I know! I am looking for one.
Interesting, though I'm not sure if my entry level roland kit would support another pad.. I'll have a butchers at the manual..Personally I'd get two singles and an additional kick pad/trigger unit. Pretty much the sole reason double pedals exist is due to the size real kick drums take up - with edrums that isn't a concern so treat yourself to the "real thing".
It's worth it!
The manual makes no mention of it and I'm not sure how I'd wire up the extra pad.
