Caporegime
- 30 Jul 2013
Just been released for x870 Tomahawk as wellAnother new X970E BIOS
- - Improve memory compatibility
- - Optimized Secure Erase mechanism.
This is important if you are using the several nvme/sata ports. I had some very strange issues with performance from a SSD then I realised that that connector wasn't connected.I've got 1 CPU 8pin plugged in and the PCIE header at the bottom as well.
Yes, just install latest, there's no need to incrementally upgradeFantastic, ill flash to latest bios after build then, typically its always the latest you need to do instead of each one, am i right?
as in the wifi aerial?I have just tried a pair of AKG Y50BT headphones with the X870E Tomahawk and I'm getting constant stuttering all the time anyone else had issues with bluetooth headphones.
Paired some Soundcore Q20's not much stutter as the AKG but still stuttering.
I have just noticed the bluetooth driver is a Qualcomm FastConnect 7800 so the bluetooth might work better if I attached my ariel lol
Ps ariel fixed the stuttering.
I’ve been having random Display Blackscreens for around 1-2s every 30mins to an hour. On the gpu and on the iGPU - disabling changed nothing.
Regardless of BIOS or AMD Drivers and a weird behavior in stress tests (display blackscreen when stopping stresstest) which I fixed with disabling C States.
The gpu was stuck on lower power levels drawing only around 20-50W.
The random display timeout still remains. But I could never force the error again and it never happenes in gaming or bios but on desktop only.
Any clues or ideas? ️
I’m thinking hardware issue of mainboard. Been dragging this issue around for 2 weeks…
Yes I’m on the newest bios and newest amd driver which came out yesterday.
I know I was getting intermittent reading s from CPU temp in Adrenaline a while back.- Fixed hardware monitor related issues.
I wonder what issues they fixed
Yes ArrBee soon as I put the WiFi antenna in the Bluetooth worked properly. Like I said it was running off the Qualcomm FastConnect 7800 adapter which is the WiFi adapter as well.as in the wifi aerial?
I assumed they were seperate. I might have to connect mine now
