To be fair i dont raise much with them, this is the first thing i have raised with them since owning the car since end of march this year. I have bought my car in for an early service (oil, filter and air filer service) 5k miles after owning, so i have been giving them money early rather than complaining.
This is the first issue i have raised.
I have raised it with BMW UK Warranty team who are going to escalate and check, i would expect a battery not to undervolt after 6 months of ownership and cause electrical alerts also because of this .
They UK warranty team are checking my escalation. the BMW official used approved warranty booklet states for 12 months, all electrical and mechanical issues are covered, they dont state all items that are covered, but they state what is not covered
under the not covered section there is no mention about battery and battery issues not being covered, also other guides online show that the battery is covered
The BMW Approved Used Car Warranty.
We believe that the minimum 12 month Warranty*
covering your BMW Approved Used Car is one of the
finest and most extensive of its type available.
Designed to protect your investment and reduce your
cost of ownership, the BMW Approved Used Car
Warranty even guarantees your vehicle’s battery and
exhaust system for the duration of the warranty.
The BMW Approved Used Car Warranty covers all
factory fitted mechanical and electrical components. In
fact, the BMW Approved Used Car Warranty is so
comprehensive we thought it more helpful to list those
few items it does not cover – rather than all those that it
does.
The only items not covered by the comprehensive
BMW Approved
Used Car Warranty are:
Brake and clutch facings, discs and drums, bulbs
(except Xenon), fuses, channels and guides, weather
strips and seals, handles, hinges and check straps,
trim, upholstery and cosmetic finishes, wheels and
tyres, wiper blades and arms, glass, auxiliary drive
belts, coolant and fuel hoses, the cleaning and
adjustment of any component and all service items or
items that will require periodic replacement. This BMW
Approved Used Car Warranty does not cover corrosion.
Wear and Tear exclusion.
As the vehicle’s age and mileage increases,
components will reach the end of their serviceable life
due to normal wear and tear or age. The repair or
replacement of components where required due to
normal wear and tear or age will not be covered by this
warranty.
Ill see what BMW UK Warrenty team say
does.
BMW Approved
warranty.
