- 21 Sep 2020
I like how they simply state “Can’t be transferred.”
When it can, it’s only once a year but using EE just saves all these headaches
Are you using your phone number or email? I had same problem when using phone number, switched to email and it workedStill can’t setup my phone without Verification Failed, unknown error.
I have gone through umpteen resets which it has automatically requested.
Even changed password.
Using email, tried transfer from phone and from iCloud backup.Are you using your phone number or email? I had same problem when using phone number, switched to email and it worked
I had the same until I used my old phone to hotspot the the new one. Loads reporting the issueUsing email, tried transfer from phone and from iCloud backup.
Both going round in circles.
I had thought of that, I will try. ThanksI had the same until I used my old phone to hotspot the the new one. Loads reporting the issue
sounds like i got lucky getting passed this then. Strange setting up hotspot works thoughI had the same until I used my old phone to hotspot the the new one. Loads reporting the issue
What was scratched? The glass, aluminium or both?Decided to cancel my order for a 17 Pro in Deep Blue after visiting the apple store (Humac) here in Copenhagen earlier, display model scratched already! Think I'll wait for some communication or resolution to that before buying.
8 hours later and I only just got this jokeI see you have the iPhone air, very nice.
I'm not in too much of a rush and I'm headed back to Jersey in a few weeks where it's around £200 cheaper for me to buy (9999 DKK vs £962) so works out okay for me in the end.
