Borderlands 4 (2025)
Did a couple of Splashzones last night, got a level 21 legendary version of the same shield I got at 14 (nice), so I guess he drops the same-ish (got legendary armour and energy shields) types , just upgraded to your level.
I get the impression that Splashzone drops far more legendaries than most other sources, probably deliberately to 'get you going' in the game.
still happening but its not as bad from the distance meh :(
I just got to this part of the map so I could see if I have the same issue.
And yes I have the same issue and no I don't think there is any way to fix it. Even turning all graphics to low/off, turning off DLSS, turning off frame gen does nothing, the issue remains on snow textures. I think its an inherent problem with the game engine
How does repeating splashzone work?
I am much higher level than when i first played is as part of the main story does it get harder?
Enemies and loot will scale to your current level so, unless you're using under-levelled gear, it shouldn't be any harder to kill him than it was originally.
Use the Moxxi's Encore machine on the other side of the ravine to respawn him.
Ty sir my friend is a lower level and finally found some time to play co-op tonight will be mine and his first time co-oping so might look to play this for some fun and lots.
