Right up until it gets covered in road crud and chain lube and looks like any other chain.
Yeah, I tend to forget that this is a 35 year old banger, not a beauty queen, as such I've just ordered a set with a basic DID chain and some Renthal sprockets.
Finally made a bit of progress. Got this bastid done and mounted back on the bike:
Also got the new tyre fitted to the rear and the wheel balanced. This afternoon I got home a bit early and had some daylight left so took the opportunity to tidy the garage a bit, this is how the bike looks atm:
All being well this weekend I'll be fitting the new chain and sprockets, refitting the rear wheel and starting on the panels.
I could've been done with this ages ago but the idea is to have it mechanically sound, so every time I find something that's even slightly questionable, it gets removed and either rebuilt or replaced. I've given up on the cosmetic side of things for now, once I've got it running and had it out for a blast I'll decide what to do with it.
To recap what's been done so far:
Valves done
Carbs rebuilt and cleaned
Tank cleaned and lined
Engine flushed
Cooling system flushed, cleaned and new coolant
New oil & filter
New plugs
Air filter cleaned properly and refitted
New fuel filter
New clutch
Fork seals done
Rear caliper rebuilt
Rear master cylinder rebuilt
New tyres & wheels balanced
Still got the chain and sprockets to do, then it should be close to MOT ready, just in time for winter
Whilst working on it I've also stripped and rebuilt quite a few mechanisms along the way, like the gear lever assembly so it feels properly crisp now, whereas it was like a flaccid dong before.
I must be honest, having done all this myself has been one of the best things I've ever done. I've learned so much and enjoyed every bit of it. The only thing I've not done myself is the tyres and wheel balancing, once I've bought a house with a decent garage I'll probably invest in some of that kit too. Screw doing forks though, for that I'll happily pay a man.
Hope the weather's good this weekend!
