- 30 Jun 2006
- Cardiff
I think I have to sit down with it and properly tune it. So I basically slotted it into my main gaming PC which uses a 9800x3d. Now it works fine but I probably should have done a fresh install but it only a placeholder until I get my grubby mitts on the 9950x3d.Yeah......no, if you cant be bothered just stick it in and enable PBO, I can do +150mhz on mine, but it took a lot of work to find limits and curves, a lot of homework and studying, and with the RAM overclock, took 2 weeks to get fully stable, verified with Core Cycler, Y-Cruncher, Prime95 Blend SSE, AVX2 and AVX512, Memtest Pro, Karhu, and AIDA64 Stress test, all 12hour ish overnight runs, TM5 for initial ram tests as it picks up errors really fast.
I haven;t noticed any stutters, any strange pauses and it is running smoothly BUT it is running slower compared to my 9800x3d and can;t hold the clocks while being stressed. My fault for not using a higher scaler and my fault for not doing a fresh install. When I say slower I mean in gaming and benching but I kinda expected that. The temps are not as bad as I thought it would be, but it does idle higher than my 9800x3d. But then again it freezing in my room.
I wish I did some productivity so I could play with it to its full potential but I am just a pure gaming geek. My original plan was to use this until the 9950x3d come out and then sell this one. But I may keep this one to either build a mitx rig or a testbench setup so I can get my tinkering jollies.
