On Zen backhaul I assume?Really regretting moving to idnet now, not only have I lost almost 300mbps of download speed, my ping has now almost doubled to 21ms
Yep I think soOn Zen backhaul I assume?
That’s likely part of the reason.Yep I think so
It’s been solid 12ms for almost 2 months, and the whole time I was on No-One, then last night it almost doubledThat’s likely part of the reason.
Here you goAnybody using Toob want to throw me a referral link before I sign up?
Assuming I shouldn't have too much of an issue hooking up my Deco P9's to the system?
Flint 2 is often recommended. It's £105 today cause of some prime sale, ~£75 on that china website (though it's actually shipped from the UK)I'm with aquiss, their 900 package, currently have an Asus rt-ax82u but it's giving me grief. The 2.4gh keeps not working and now I have an EV charger it's annoying me having to restart the router.
What router do people recommend for good WiFi range?
Do Aquiss not provide a router or is it just not very good?
Just noticed aquiss have a recommended routers page but it's just all TP Link stuff
Do none of the ISPs provide one? Seems a bit odd to not even have the option to get one through them. Guess it makes support easy for them as can just blame the router.Don't provide one
Edit
I'm quite happy with my Unifi Pro access point so hopefully the non WiFi routers are cheaper. Need to do some more research into this as not a fan of tp link.
The new UniFi gateways are excellent, using a CGF myself with EE 1.6 Gbps, it's fast and stable and works well within the UniFi ecosystem.I'm quite happy with my Unifi Pro access point so hopefully the non WiFi routers are cheaper. Need to do some more research into this as not a fan of tp link.
I have 2 unifi gb switches as well but only because i got them from work. Don't really like anything from them other than the access points. I suppose I should look for something with 2.5gbps LAN ports just in case I upgrade.The new UniFi gateways are excellent, using a CGF myself with EE 1.6 Gbps, it's fast and stable and works well within the UniFi ecosystem.
Have you tried their gateways with recent Network Application versions?Don't really like anything from them other than the access points.
I've not used a gateway device for a couple of years now to be fair. Their dream machines were awful too, had to support a couple of them unfortunately. Looks like the Cloud Gateway Max is what I'd need but kind of begrudge paying that sort of money for something the ISP should provide. Making me think I should just use a different provider.Have you tried their gateways with recent Network Application versions?
