City Fibre
Anybody using Toob want to throw me a referral link before I sign up?
Assuming I shouldn't have too much of an issue hooking up my Deco P9's to the system?
Here you go :) https://rewards.toob.co.uk/cam4re
You should be able to use the Deco's no problem, the engineer that installed mine hooked the included Linksys up to test the connection but after he left I put that back in the box and connect the ONT to my UDM Pro.
I'm with aquiss, their 900 package, currently have an Asus rt-ax82u but it's giving me grief. The 2.4gh keeps not working and now I have an EV charger it's annoying me having to restart the router.
What router do people recommend for good WiFi range?
Flint 2 is often recommended. It's £105 today cause of some prime sale, ~£75 on that china website (though it's actually shipped from the UK)
Just noticed aquiss have a recommended routers page but it's just all TP Link stuff
I got the TP Link BE550 after their recommendation and had 0 issues with it so far, one of the cheaper routers that has 4 2.5gb lan ports (at the time I bought it)
Don't provide one
Do none of the ISPs provide one? Seems a bit odd to not even have the option to get one through them. Guess it makes support easy for them as can just blame the router.
Edit
I'm quite happy with my Unifi Pro access point so hopefully the non WiFi routers are cheaper. Need to do some more research into this as not a fan of tp link.
Edit
Aquiss is the first one I've been with on a CF connection that didn't supply one.
Giganet gave a Eero 6 that I had to send back when I switched, No One sent a Merku (this was before Home Telecom bought them so not sure what they send now)
The new UniFi gateways are excellent, using a CGF myself with EE 1.6 Gbps, it's fast and stable and works well within the UniFi ecosystem.
I have 2 unifi gb switches as well but only because i got them from work. Don't really like anything from them other than the access points. I suppose I should look for something with 2.5gbps LAN ports just in case I upgrade.
Have you tried their gateways with recent Network Application versions?
I've not used a gateway device for a couple of years now to be fair. Their dream machines were awful too, had to support a couple of them unfortunately. Looks like the Cloud Gateway Max is what I'd need but kind of begrudge paying that sort of money for something the ISP should provide. Making me think I should just use a different provider.
