- 19 Oct 2002
- Shakespeare’s County
You might think this is a problem in the future, but you are actually already dead. Grim Reaper has swung his scythe.
Took the Countryman to my local tyre fitter to investigate a slow puncture.
Found an punctured shoulder that's not able to be repaired. Sadly only budget tyres in stock, and a matching Michelin would be on backorder until November after he rang around, so settled on a Hankook which should be here this afternoon/tomorrow morning.
(In before the mismatched tyres = instant death comments)
Tyre fitted and made it home without crashing
Scanned the Countyman for codes after my wife got a power steering warning appear on the dash.
Power steering under voltage historic fault logged. I'm assuming might just be the first signs of a failing battery, as it's likely the original from 2017, and is only showing 74% state of charge even after an hour's drive.
Will order a new battery at the weekend, as need to take half the engine bay apart to even check what size is currently on it.
Also don't tell @DJMK4 but when I scanned for codes I had 80 info error codes! (Many of which I still can't clear)
No idea why the engine bay is so dusty, but that can be done next time I have the pressure washer out
This guy has a special set of skills - mesmerising & reminded me of classic daily bread documentary.
imagine what wage he'd get in the UK - no butt welding
e: wondered what brand of battery tools they use
Was confused reading this as thought it was my post about the Mrs car.Took the Countryman to my local tyre fitter to investigate a slow puncture.
Happened to me a couple months ago too. Had a screw on one of my rear Michelin CC2s and wasn't repairable. A matching CC2 was on backorder until the following week and they only had budget tyres in stock. I had a long drive with the Mrs the next day, so had no choice but to settle with a mismatched budget unfortunately.It really sucks when this happens and they have nothing decent in!
