A black one, specifically. Don't forget the matching puffer jacket.You're on a scooter, just wear a balaclava.
Just leave the mirrors off - less drag, can get up to some proper speeds thenMirror extenders arrived, can't get them to fit- incorrect thread on the bolt from part to handlebar fitting (thats correctable with replacement bolts) however mirror to part is also regular thread direction so it wont thread. If I remove the thread on the part for that hole then a reverse threadnut wouldn't fit on the on the other side either, as the underside is angled.
So basically need four items, two thread adapters and two reverse thread bolts
Fingers crossed for you buddyGot a call from the dealer and my bike/gearbox is back together, they just need to test ride it tomorrow to confirm it's back to where it should be (and just in time for winter).
Excitement 10/10
Expectation 1/10
So, is learning to ride in winter a bit of a mad idea??
Not really, no reason not to (obviously not in snow/ice).So, is learning to ride in winter a bit of a mad idea??
So what was the problem ?It's back!!!
So far, so good, just need to give it a proper ride to check all is well.
Nearly got flattened by some daft bint who didn't see me, and that was before I even got off the dealers premises (I'll post a vid later).
I immediately took off the standard can and put the asbo one back on
Unfortunately it'll now get laid up for winter.
Not at all. The best time to learn is now as a lot of people learning to ride will now put it off until spring. This time of year is your best opportunity.So, is learning to ride in winter a bit of a mad idea??
As far as I know they replaced the 2nd gear.So what was the problem ?
