NVIDIA RTX 50 SERIES - Technical/General Discussion
Well my 5090 has started having fan buzzing issues... again... this will be the 2nd time doing an RMA for the same exact issue. Card is fine but the company Zotac sources their fans from seem to be cheap crap.
Watercool it :D
I have bad luck with tech in general, Adding WC into the mix would be like walking into a thunderstorm with a 50 foot tall conducting rod and saying "I'm totally safe" :D
Man that's such a PITA for such an expensive card eh. Grr.
It seems to have sorted itself out for now, Maybe some lubrication finally got into it.
So just installed a new 5080FE in my secondary machine.
To cut a long story short, I get no output at all when connected via DP but it's fine on HDMI.
After a bit of Googling, it appears this is a known issue whereby the card doesn't detect the monitor when it's in standby.
A few people have recommended using the monitor's OSD to keep it "alive" while the computer boots but this doesn't work for me.
I'm thus stuck with HDMI which is unacceptable as Freesync doesn't work over that connection.
Does anyone have any ideas?
Is this a monitor specific issue? I have a fairly cheapo Gigabyte G27Q.
Yet to try connecting it to my other monitor to see if that works.
I'd try the other monitor. DP can be funky with certain standby implementations I know. It's also true it can just completely get "hidden" to the GPU. Something that always used to bother me personally was programs like AnyDesk and a previous DP monitor(funnily enough think it was also gigabyte!) - you had the leave the monitor on else trying to remote into the PC would cause you to get no desktop due to how the software worked and the fact that the GPU couldn't see the monitor anymore.
Ignore me, managed to get it working with some prodding of the monitor :)
So ordered an FE from Nvidia two days ago. No confirmation emails whatsoever and order on their site just says 'Processing'.
Is this normal?
As the card is out of stock again, I'm now questioning whether I've actually been allocated one or just gone back into a queue?
Whole system is garbage compared to the old system used for 30 and 40 series cards.
(Hope this doesn't violate competitor rules as OcUK don't sell FE cards).
I was just being curious to see what the price of FE cards are going for on the Nvidia site and there are no FE 5080 or FE 5090 listed. No "out of stock", just completely missing from their site.
I wonder if they've stopped making them now.
Hopefully the supers are incoming
