Intel Core Ultra 9 285k 'Arrow Lake' Discussion/News ("15th gen") on LGA-1851
200S Boost will increase the VDD/Q up to a maximum value of 1.40 and increase the NGU and D2D to a ratio of 32, which greatly improves performance.
I'm curious why HUB didn't use it in the round of performance testing, as it will bring a noticeable uplift in performance but I guess they are hardware unboxed, which are load and go specialists.
This made me laugh in BF6 at the frame rate with Frame Gen:
Yeah, I've found 200S boost to be really solid across all games I'm playing.
Before it was introduced I was manually bumping up the ring clock but overall 200S boost is ideal for just a 'set and forget' in BIOS. I'm surprised Hardware Unboxed aren't using it in any of the benchmarks.
Over 1000FPS is hilarious, how did it feel latency wise at 4x?
Yeah, I'm on 200S Boost but haven't enabled game mode. From memory game mode doesn't tend to help with all games, only certain titles.
Are you able to use that 200s boost and still be able to undervolt..?
My Gigabyte BIOS offers Ultra Turbo Mode, settings based on, but greater than, the Intel's 200s.
Thanks
Thanks
Not with the Intel profile. If I copy the Intel settings manually and use the Asrock performance profile in BIOS I can undervolt!
mmmm. Using that profile in the Gigabyte board then locks access to a lot of settings, except I am still able to manually offset the vcore with a negative value.
As well as ring voltage offset, that is also adjustable.
[/URL]
This is fairly interesting, using the 285K on BF6
Stock 285K / D2D 32 / NGU 32 / Cache Default (38) / 9000 XMP (G.Skill Trident Z CK)
User.cfg set to the following:
Code:
Thread.ProcessorCount 8
Thread.MaxProcessorCount 8
Thread.MinFreeProcessorCount 0
Thread.JobThreadPriority 0
Gstrender.Thread.MaxProcessorCount 24
In terms of power draw, it is around ~100W, which is quite impressive given its ~200fps @ 4K
Code:
As you've got this and the 9950X3D and with what t2na said about it feeling 'smoother' what's your thoughts?
I've got a different motherboard arriving today to use with my 9800X3D to see if that has any impact, my B650-E (i) was always a little ropey so potentially could have some factor in it.
I thought they were about the same once fixed, but I have only been playing the game at 4K in BF6, as both have consistently over 200 fps @ 4K High settings. The 9950X3D out of the box does seem to have a core parking issue (Update Windows Game Bar and Remember this game), which does cause the lows to drop and then doing the user config setup to keep it on a single CCD. So from that perspective, yes, it would feel smoother as the gap between the highs and lows is greater. I'll capture some rounds over the weekend.
I've also got a working recreation of the HUB BM, which is interesting.
One odd thing I have been reading about is using Server 2025, as it seems to bump the performance quite a bit, so when I get time, I'll have a look at that as well.
So, there can still be times when you can't rely on an OOB experience being optimal with the 9950X3D.
Not that it is a major issue, but one that needs awareness of recognising it and then how to resolve.
Interesting.
So, from the video, "there are no special settings that can be applied to make your 285k go brrrrrrrrrrrr"
lol.
All hail the 9800x3D, for gaming.
Just to add a little note to this, my B850-I is definitely working a lot better than my B650E-I with this 9800X3D. Coil whine has disappeared completely and I'm suspecting there were some VRM issues on this B650E-I.
I'm going to run proper tests of it later vs. the 265k build (it's not apples to apples, the 265k is cooled by a 280mm AIO in a mid tower case, the 9800X3D is in an SFF case cooled by a D12L) but should give me a decent overview of the two against each other.
I'll take a post direct from reddit but it sums it up nicely:
Yes, let the data speak for itself. You're putting an awfully lot of faith on HUB when they never show their recorded benchmark footage or frametime charts.
Stop glazing HUB, they're not without flaws. Should be noted that HUB's critics came with their own claims and data - often times more detailed than what HUB has shown thus far.
Those " Intel afficionados" aren't nobodies. You had CapFrameX dev, OCN members and smaller youtubers commenting on HUB's flawed BF6 CPU results. Those individuals showed their entire testing methodology, frametime charts, and recorded test-runs as proof. On average their frame rates in BF6 was +30%-45% higher than HUB's 285K and 14900K result. They also re-validated their results via multiple re-tests.
TLDR/TLDW; The conclusion is a rather boring one. Either one of these CPUs is neck-neck and will provide you with a great experience. You're going to hit a game engine limit once you reach 299 fps.
Then HUB moves the goal posts, produces this video in a 'I told you so' fashion with different games, different testing parameters and didn't even bother including BF6 as part of the test bench....
Now with the goal posts moved, you once again have people starting to question the numbers as it's not lining up. How does a 4090 outperform a 5090 in 1080p?
Not that I really expected much from this refresh, but even so it seems a little disappointing.
It’s a refresh, so that’s normally only clock speed bumps. That does put the 290K Plus in rather an odd spot as a pre binned special.
What I do find interesting is they have bumped the memory speed up which is something that normally doesn’t happen.
However, what I said in the Zen6 thread about Arrow Lakes shortfalls are not clock speed related; they are down to the Cache / IO. While not a perfect answer, you can overcome some of those by increasing the D2D / NGU / Cache / RAM, as I don't know why out of the box they are stupidly low (26), and there is also a bug (or safeguard) where it sets the tWRWR_sg (89+) incorrectly, which causes the writes to be much slower than they should be.
If any of that has been changed that would bring a good uplift over stock 265/285K’s
I’ll pick a few up as normal and see how it goes.
Yeah, I'll grab a 270k to see how it compares. Really interesting to see if they stick with the 8P/16E core approach for the Ultra 7 range going forward too or whether it's just a one off for this refresh.
Let us know how you get on please.
