I haven't washed rice for 20 years.I stopped washing mine recently doesn't seem to make much if any difference.
My partner made me do a blind taste test on washed and unwashed rice. Annoyingly I could tell the difference straight away much to the amusement of my partner.I haven't washed rice for 20 years.
It stuck together less and the texture and appearance was far better. I think it’s to do with the starch, happy to be corrected on that though.Was there much in it?
I must admit I stopped bothering as I could never really tell any different.
But must admit I've not tried a taste test like that, I might give it a go.
Cooked the 1/2 cup to throw before first use as they suggest. Jasmine, washed it thrice, it was awful? Clumpy, burnt and browned when opened with only 2 minutes on the "keep warm" timer. The bowls a bit awkward to remove too because it's set so deep with only a small lip, and you can hear it scratch on the shell which is concerning.Got a bit fed up of the browning in my simple plate so I've bought a Panda. Holds just enough for me + my partner plus leftover for next day. Also bought some brown basmati to use with it, never had brown rice so we'll see.
What are G plugs? Taitung rice cooker, I keep banging the drum. It looks basic but it’s faultless for me and my partner.Cooked the 1/2 cup to throw before first use as they suggest. Jasmine, washed it thrice, it was awful? Clumpy, burnt and browned when opened with only 2 minutes on the "keep warm" timer. The bowls a bit awkward to remove too because it's set so deep with only a small lip, and you can hear it scratch on the shell which is concerning.
It'll be going back. What alternatives are there given Zojirushi, Tiger and Cuckoo don't seem to support type G plugs without paying absurd import fees for a Singapore/HK one.
Type G plugs are what we use in the UK, our 3 pin plugs.What are G plugs? Taitung rice cooker, I keep banging the drum. It looks basic but it’s faultless for me and my partner.
If I can cook great rice on it anyone can.Turns out it's a bit of user issue but not really. I did the throwaway 1/2 cup exactly as stated by the handbook, which looks to intentionally use less water hence the burning and browning. Cooked 1.5 cups of basmati last night with a more standard amount of water and it turned out fine - there was no browning and the texture was consistent throughout even after 1 hour on keep warm (my old rice cooker would burn the bottom within minutes of standing with no water).Cooked the 1/2 cup to throw before first use as they suggest. Jasmine, washed it thrice, it was awful? Clumpy, burnt and browned when opened with only 2 minutes on the "keep warm" timer. The bowls a bit awkward to remove too because it's set so deep with only a small lip, and you can hear it scratch on the shell which is concerning.
and the other professionals aren't either - unfortunately the buffalo one he shows is a massive 4L but 'only' £80Walk round your local uni and see what every Asian student is using in their dorms. It isn’t the Japanese brands
Kohinoor basmati rice on special at Tesco right now, we just paid £11.75 for a ten kilo
Kohinoor basmati rice on special at Tesco right now, we just paid £11.75 for a ten kilo bag.
