What a two day willy pain. So I got over yesterday about 1. The rails were here waiting. However, when I went to fit them I noticed a big ****** problem. The old rails were counter sunk into the front and rear panels. Meaning my new rails I just spent £25 on were too short. I then had the genius idea to flip? inverse? mirror? then front and end. This led to a 5 hour fight. In the end I assembled it with the rails loose, intending to get my mate to make some spacers.
Then it dawned on me that
it was possible but because I had forgotten to flip inverse etc the limit switches it seemed like the bed was on wrong. So I then got back up and spent another two hours putting it back together. Just the bed. It took around 8 hours fgs.
Got up today and put on a F ton of sound deadening. You will also note there is a new spoilboard I made. I also had to extend (add in cable) the limit switches as one was getting tangled in the bed, and one was just not long enough. So after another 6 hours today......
You will note there is no plastic on this machine apart from the sides I made today.
So how is it? incredible. It now machines twice as fast without snapping bits, whilst making hardly any noise above the sound of the motor.
Oh also. You will note the bed is quite a fair bit wider. That's because it is. You don't lose 15mm each side out of your 300mm any more. You can machine the entire 300mm. You can also see where I put the old rails too, as the Pro Ultra comes with thicker side metal things.
