Road Cycling
I sold the bike in the end, I got a good offer and made a decent amount on the bike so there is no love lost.. It was an old 2014 campag athrna 11 that had one of their funky square axel from what I found when I researched and 25mm in width.
I'm now looking at maybe just having my roadie and a redshift seatpost: https://www.sigmasports.com/item/Re...InArUGl_SORhdEqi9909L8XhTSLzaDBBoCG14QAvD_BwE
With some clip on tri bars, saves me a lot of cash and should get me 75-80% of a tri bike without the headache :D
As you got good money for the bike all good, let someone else have the hassle! Yeah with that seatpost could get much of the way with aerobars, but also consider get some solid training in and do some TT's like that. When you get to the point of chasing some real targets and times the 'what if' will sneak back in and you'll be looking at TT bikes again! Think the Cervelo P2 is still quite a standard for people starting out and they've always come with many groupset options so less likely to have a similar issue... Also lots of people buy (& sell) them as framesets.
Flip stem to point upwards to reduce its effective reach by ~15cm if +/- 6 degrees
Put all fork spacers under stem to reduce effective reach, roughly 30mm spacers is ~10mm reach
All these easy options without changing what you have @Martynt74 but another - never discount, certainly when troubleshooting issues, just loosening the stem and rotating your bars back towards you. Quick & simple to reduce reach! No bartape or even taking things off... At least until you find a better position/measurement then figure out how to get it so it 'looks good' rather than something you ride hidden in your garage at home hoping nobody sees :D
There's been a spate of bike jackings in our area, on roads I usually ride on... I almost didn't go out this morning, but I guess you can't live in fear! Both bikes have Moto Tags, but I expect they're used to looking for those these days. I have just registered them both on The National Cycle Database.
Be careful Andy! At the end of the day a bike is not worth getting assaulted over, we insure them for a reason and might be worth checking armed hijacking is covered...!
Went out for the first time with a local club on Sunday. Was good fun. The thing that struct me most was how **** a lot of drivers were at overtaking. Goes to show that as soon as you are an actual impediment to drivers or inconvenience them for more than 30s, a large number of people drive like complete *****. So many overtakes on blind corners and not even the type you get as a solo rider where they are over quite quickly. Mind boggling really.
Yup, thankfully a small number of them around here but always had run-ins with idiots. Tend to see more of them on a weekend than weekday when group riding!
Here it seems the 'poor' overtakes and lazy driver type things (like not giving way & pointless overtakes) seem to have got worse the last few years. Vehicles have got bigger and drivers seem more complacent or distracted than ever before.
Almost time to switch over to the winter bike full time now. Just scraping in a few more rides on the summer bike. Yesterday was a nice day. This week looks a bit ropey.
Darker evenings are not fun though.
Yeah having gloomy mornings the last couple of weeks didn't notice a huge amount of difference so far this week... But the towards-dark commute home was quite a shock!
when the weather is OK.
:cry: :cry: :cry:
i can feel some side to side rocking if i hold the thead and wiggle the pedal forwards and backwards. Anyone else have had issues with look pedals?
Fairly normal for a pedal once it wears. Should be minor play ie less than 1mm, much more than that you might have a duff/worn bearing if they where new get them replaced. But if not/too old for that then just ride them. Some of them you can tighten up - there's a plastic collar around the axle which holds it into the body. As the outside of the pedal is a 'needle bearing' which is like an axle into a bushing there's several mm of play/movement there without issue. The collar end is the main 'normal' cartridge type bearing (with balls in it). But they're generally fixed on the axle, almost impossible to remove and then also almost impossible to get them to replace even if you could get the thing off the axle. As there's replacement axles for the expensive pedals (like Blade) you just change the whole unit, but they're so expensive not worth it on a cheaper pedal. I like the Keo Blade & Max pedals, but the price of them these days I'm just riding Classic everywhere. There's just no gain to riding the more expensive ones...
Stem is fixed, so can't make any changes to the stem/bars without swapping
Ha there is a cervelo p2 around the corner for me listed at £400, ultegra 10 speed, I have been tempted..
Right, got my 32c GP5000 AS TR tyres on the TCR. Will be interesting to see how they feel vs the old 30/28c GP500 S TRs they have replaced. I would say they are clearly a meatier tyre just from handling them and putting them on the rim.
I need to start making a note of when I put tyres on my bike. The 30c rear that i've just taken off is obviously quite squared off and the wear indicators are about 95% done. I bought the tyre in June 23 but I have no idea when it eventually made it onto my bike. Certainly feels like the S TR doesn't last that long on the **** that passes for roads around here.
I did not. What feature is this?
You add "Gear" and set them as defaults and then it tracks your usage. I always struggle to find it but it's under your profile. You create a bike and then add components, you then assign that bike to your activities and it keeps track
I'm lazy and just have the bike setup instead.
  • Like
Reactions: fez
Made it down to Cartagena for the ride. Decided to see how I felt as the split for the 50km and 80km routes was around 35km
Hit that point and bailed for the 50km. Could tell I’m still a bit run down from illness. Especially the biggish climb where my HR was hitting 190.
Probably couldn’t carried on for the 80km version if I really wanted but decided it was more important to be sensible and try and ride tomorrow instead.
Cracking route though. So will do it again next year I think.
Also just realised that I left my helmet on the roof of the car when I was loading my bike into the boot and it must’ve flown off at some point leaving the car park.
I blame rushing because the pizza place shut at 4pm and Google maps said I’d get there at 3:50!
Went for a ride today and once again Strava came up with a stupid route so just made my own way instead, think I have to start pre-checking all the routes it suggests in good detail so it doesn't take me onto roads that aren't suitable.
Ended up as 45km still so not too bad, at least decent weather today.
Mate got run off the road yesterday. Haven't spoken to him properly but sounds like he had to bin it into the hedge to avoid being hit. Naturally it was some **** in a pickup truck. Said the guy was laughing as he went past so hes pretty certain it was intentional. This is why we put cameras on our bikes. Too many pathetic human beings about.
sounds like the right combo, pickup and a *****.
Unfortunately, from my experience you just need to say the former and the latter is almost guaranteed. Don't know what it is about people in pickups but they are definitely bred from the same pool of people who drive the open bed scrap metal style trucks. Drive like *****, don't give a **** about anyone but themselves.
I was close to buying a pickup recently….
Are you feeling an urge to drive like a *****? Is your penis shrinking the more you think about it?
Its like all these things, they appeal to a certain demographic as well as being a tool for people who work in certain businesses which again attract a certain type of person. There are exceptions obviously but its the same with things like expensive Land Rovers. The occasional one is a good driver and courteous and kind. The majority are ******** who think they are better than everyone else and their massive wankpanzer gives them the right to do as they please.
A car obviously doesn't make someone a ******* but certain ones certainly do attract them.
