- 2 Aug 2016
Yeah, I did review the script before running.
What would be better is an option to uninstall itImagine there was a simple slider within the OS to turn AI stuff off.
macOS enters the chat.
Hi. i have 24h2 on a local account on my home pc.
If i install 25h2 on my pc will it still remain a local account or will it force me to create a Microsoft account?
I have read lots of conflicting rubbish!!
I did a clean install of 25H2 yesterday and created a local account without any issues. This was on a VMHi. i have 24h2 on a local account on my home pc.
Indeed, its a shame there is not another option. Windows without the bloat\AI, funny thing is I would pay for a light version where this crap is not includedI'd consider other options if people want rid of the AI 'features'.
MS themselves say Windows will become an agentic OS, it's only going one way at the moment.
Yeah the Anti cheat is an issue, I haven't played games that need it for a while now so I'm on W10 extended updates as I switch to Bazzite.Indeed, its a shame there is not another option. Windows without the bloat\AI, funny thing is I would pay for a light version where this crap is not included
I've looked at Bazzite but some games with Anti Cheat do not work so its not so easy to switch.
I know what you mean.Yeah the Anti cheat is an issue, I haven't played games that need it for a while now so I'm on W10 extended updates as I switch to Bazzite.
I don't have a problem with 'AI' per se but not having control on whether you do have progressively more and more taken out of your hands does bother me.
Yes it will stay as a local account my laptop acts the same no annoying messages.Hi. i have 24h2 on a local account on my home pc.
I think its Normally based off hardware ID or your Microsoft accountIf you wipe W10 and install from scratch, activation is based on motherboard MAC address, right?
Most likely never fixed them and resolved in 25H2 rather than fix 24H2 and just skip it.My pc finally kicking in with the 24h2 update. I wonder if they've fixed the bugs in that year they've had - or just added more.
Hold shift and drag the window where you want. Next window should open in the same place (shifted if original is still open) and size.All of a sudden my file explorer windows don't remember size and position, I've tried the fixes on Google but none had done the trick, any ideas folks?
Nope, still opens small and in the middle of the screen, no matter what I do!
I have no idea whats changed, windows update?
