Don
- 20 Oct 2002
- Oxfordshire / Bucks
where you meant to put that comment in the steam frame thread ?
thanks for taking the time to reply, i did read somewhere that connecting the quest to wifi 7 jangles with its wifi, so you need to disable the 6ghz frequency,not wifi 7 but i think the headset only suyppots 6e.
i usse wifi 5 works well, or a wired connection depending what imn doing and were.
no reason i can think of your setting doesnt work through
if you have an old router see if it supports access point mode
and put it between the pc andyour eithernet connection would be my suggestion
Is the Quest 3 limited to 4k video? When I tried 8k it freezes, even 6k won't work?
8k videos usually work fine on Quest 3. Have you tried copying the video locally onto the device as it might be your network/wifi or source device are too slow to stream it smoothly?
Do you know what format the video is in?
i just thought the wifi7 on the pc was sat wasting away, so would be a shame to not put it to use
I have bought one yet, just working out the options, at this point id be suprised to see a steam frame in my hands by february, and even then im a little worried, as there has been nothing shown about its actual VR capabilities, so im kinda resigned to the fact i'll probably be getting a quest 3 even if its just to fill the gap!, but i dont think im gonna be dissapointed with the quest 3, does seem to get a lot of praise for the moneyDid you try it? The results can vary. It might work really well for you, it might be utter crap. Windows Hotspots are iffy at best. There used to be a whole process you had to go through to get it setup to work with Quest headsets, not sure if it's still the case.
Anyone got a referral code for the free credit?
I know this is the quest 3 thread, which is a bit confusing with all the talk about the Steam Frame, but this is the absolute worse time to be launching new hardware..
Also given the specs and predicted price, I wonder if they'd be better putting the launch off for at least 12 months.. see what Q4 brings, and compete with that.. because at the moment, if they prioritise profit, the steam frame just feels dead in the water..
Worst time in what way?
