x870e asrock phantom nova
Will update later but so far not had a single issue with v3.30. PC in use every other day gaming for hours Expo enabled with all timings adjusted but PBO settings all default.
I was going to order this board, but then realised they have done a slight refresh, with the Nova non-E variant. In my opinion it is better because it has no PCIE x1 slot, favouring a a second x16 gen 4 slot and 2x gen 5 PCIE m.2 slots and revised wifi 7 antenna, also updated to BIOS 3.5.
For £270 delivered, it’s the best board out there at the moment, even better than my Gigabyte Aorus x870e Master!
The Nova is running a 9950X3D and a 5090 like a champ.
Not updated since 3.40
Will need to get around to this, guessing I best take notes of my current bios settings as I have my CPU running at 65w with -30 on all cores. Do you guys reset BIOS to default before updating?
Nah, the only thing you have to do is "load defaults" after the bios update completes, then "save the changes" and exit. Then, go back into BIOS and reapply your settings. :)
