- 14 Apr 2014
- Hampshire
Thank you.
I will have a look around for the best deal on the AVA P50.
Snow foam question...need to restock, and CYC have a 10% sale at the moment. I've used Bilt Hamber Auto Foam pretty much exclusively for years, but how does Touchless compare? I remember it coming out a couple of years ago but just not got around to buying some yet. Can't work out if it's more effective than Auto Foam, or has a different application.
Some blurb seems to suggest its actually gentler and less effective as a cleaner than Auto Foam, and intended for more regular use...but then I do snow foam pretty much every wash. Any personal experiences or preference?
Are there any reasonable Karcher alternatives I should consider as replacement please?
I have an aftermarket 15 metre flexible non coil hose, trigger gun and foam cannon all with Karcher fittings so prefer to be able to use these with a new jet washer.
I think some of the Karchers now come with universal motors rather than the induction motors, does this impact real world use?....
What's your process for applying the D300? I've not had the balls to try a compound on glass, but my car is getting close to needing it![]()
Not too shabby!
Just recently bought Bilt Hamber Trace Less Glass Cleaner and 3D Bead It Up.
Both did a very good job. I'm struggling with contamination on my glass cloths. The lint fibres are back! Got some new ones on order. I do my best to keep everything separate but I just think natural dust and fluff around in the air eventually gets to them. Brushing against clothing, etc. Anywho, the 3D Bead It Up, actually went on the exterior glass well and buffed off OK. Used two cloths and made sure to buff it more than it probably needed; nothing worse thinking its clean, drive into the sun and see the smears. lol.
Not too shabby!
Thanks. So far I've tried:
It probably doesn't help that others in the household use the clothes horse for hanging regular towels and dish towels etc on, whilst, I have the glass cloths freshly washed air drying. I need to get a separate clothes horse and keep it away from the other towels. Apparently I need to relax and stop fretting but when a cloth costs like a tenner a go, they are easily ruined. lolIt’s the static unfortunately.
Cleaning the interior first can help
Ooh really! Now that's an idea! How does the Squeegee cope with the curved windscreen? I'd imagine for side windows it works well.It’s why I’ve stopped cleaning glass with a micro fibre. It’s near impossible to keep them lint free.
Squeegee works much better![]()
