- 14 Jun 2004
pop by the social thread if you feel like you might want to try multiplay with others, if you dont already have peopeclay huntvr, the main reason i got it, but will be getting more soon
I tried some rubber grips that covered the controllers and it messed up the tracking.I'm thinking I might try some of the controller grips with straps as I'm getting cramp in my hands playing for extended sessions.
Any other recommendations for Quest 3 Controller grips/straps?
Oh some cheap silicone things from Aliexpress. I don't need them anyway since I only use VR for racing.Which ones did you get? Mine are very good
It turned up today. It comes with two thicknesses of vecroable cushion, and the center section of the cushion nearest the forehead is sprung loaded for a little more comfort and better fit. Still 75% off at John Lewismuch cheapness -
Meta Quest 3 Open Facial Interface for Meta Quest 3, Black
Buy Meta Quest 3 Open Facial Interface for Meta Quest 3, Black from our Virtual Reality range at John Lewis & Partners. Free Delivery on orders over £50.www.johnlewis.com
I bought this, v good for the price imo, especially for when using passthrough as it adds to the fov.It turned up today. It comes with two thicknesses of vecroable cushion, and the center section of the cushion nearest the forehead is sprung loaded for a little more comfort and better fit. Still 75% off at John Lewis
We have checked the photo you provided.
We apologize for any inconvenience caused to you.
After communicating with the product owner, we would like to issue you a new replacement.
Could you tell us your full delivery address and telephone number?
At the same time, we attach great importance to this issue.
The cause of the problem and the solution will be discussed at the upcoming product meeting.
I'm here waiting for your reply.
Best regards
Quest 3 open interface back in stock at John Lewis, much cheapness and indispensable during a heatwave. £7.97
