How much more do you want to give people who are in a position to afford a new car?Honestly I think they should give 3 years grace to the PPM tax for new EVs/PHEVs to tally up with the first MOT. Would provide incentive to buy new EVs and also reduce the admin burden and associated costs.
The EV grant should be abolished no doubt about it. The 3 years grace for ppm for new EVs would be reasonable to reduce the admin burden, and give an incentive to buy new EVs (replacing the grant).How much more do you want to give people who are in a position to afford a new car?
The used car market is dependent on new cars entering said market so I think it's reasonablebut imo they need to stop giving sweetners to those who can afford to get a brand new car whilst offsetting those costs by butt .... ing those buying 2nd hand cars, as well as screwing over those who knowing payed more up front for an EV on the promise of cheap running costs that would save money over the lifetime of the car.
Ppm for ice cars is basically baked into the fuel duty already, the EV ppm scheme basically brings this to EV vehicles at half the rate (or less depending on fuel prices).pay per mile will need to come in at some point, but if they want EVs to be genuinely encouraged over ice imo they should be added to all NEW cars (ICE and EV)
going from my 440i to my model 3 the cost to change was £600 (sold my 440i for £20k, my model 3 cost £20.6k) and from the depreciation graphs when i was researching, a 3 year old EV had the same depreciation curve as its ICE equivalent going forwards as someone already paid for the massive depreciation in the 3 years prior
installing an EV charger at home was £1k
the insurance was £400 cheaper on the model 3
saved £260/yr on not paying the bmw insured warranty
saving about £400/yr as no yearly servicing required
4k miles travelled on my model 3 to date about 8 months
total electricity cost: £86 - this includes a handful of supercharging stops i did during the summer
the equivalent in my 440i (lifetime average was 32mpg using RON98/99...assume about 150p/L) = £848
so basically in 8 months, i'm already quids in (saved about £260) and the difference is going to get larger as the running costs (insurance, servicing, fuel) is so much cheaper with an EV for me. as always, YMMV
Will have to see this (C Class Electric) in the flesh before deciding my real feelings on it, could be a contender in the very short list.
Loading…
www.topgear.com
Loading…
www.topgear.com
They drove a fairly low spec model with the base 20" wheels and achieved fairly impressive range figures.
with higher speeds, and found one with cruise set at 85-87mph,doing a cornwall run, 66mph average, with ~30% of the journey at 85+ mph (adaptive cruise again)
I have a feeling I've screwed myself into the higher VED bracket.
The car I have a receipt for was £49,990. But because I wasn't going to recieve it before the quarter ended they changed me to a car with premium paint... so if I understand the rules correctly it doesn't matter my deal was 49,990 I would be over the 50k threshhold![]()
If the RRP is over 50k, then I think so :/
Whose fault is it?I have a feeling I've screwed myself into the higher VED bracket.
Whose fault is it?
If it's their fault I'd be on the blower pronto aiming to get a discount. An extra £2k is a lot!
So headline numbers were, 100kph average, up to 130kph when they could, and did 529km with 90% of the battery..
In UK terms, that's an average of 62mph, max of 80mph and 328 miles on 98kwh of battery (90% of 108.7kW) which works out at 3.3m/kwh..
Its OK, but fairly middle of the road.. The reason it sounds impressive is purely the size of battery, that's a massive battery pack..
3.8 miles per kWh at 60mph and 2.8 miles per kWh at 80mph.
Thanks, I just watched the whole video and spotted those in the middle!3.8 miles per kWh at 60mph and 2.8 miles per kWh at 80mph.
EVDB has no actual real world data for the new iX3, its all hypothetical, but I do agree we need more direct comparisons, I'm just saying that the YT video claiming impressive efficiency seems really exaggerating things by then presenting pretty middle of the road numbers.Any experienced EV driver also knows it’s pointless comparing these numbers unless they were identical trips in identical conditions.
Even a mild tailwind vs headwind can make the same journey comparison totally invalid.
I find EVDB gives a solid reference for what to expect in identical conditions. And from EVDB an iX3 is about 8% less efficient than Model Y AWD Juniper. It is also about 13% heavier and will give about 100 miles more range.
What it does bring to the table is a huge battery with decent enough efficiency and good charging, which will make it useful in some situations, but the way people are talking is like it sets some new benchmarks which so far from all the data coming in just isn't true.
The only tests I kind of think are fair are the Whatcar ones they do in convoy with the aim of trying to get as fair a result as they can, but even they go stupid when working out charging costs, but at least the majority of the actual range/efficiency tests are done under the same conditions!True on EVDB for now but their numbers will still be far more valid than some test drives done in different conditions and environments
Hopefully it'll grow on people, I'm still test driving one on Wednesday, followed immediately after by a Juniper model Y AWD Premium.. I have no doubts the iX3 will be a little more refined overall, I just want to experience how much as I do want to be tempted away from just getting another Model Y at the end of the year..I agree the iX3 seems a lot of hype from the mainstream reviewers for something that is nothing that special. I made a post in this thread saying I had sat in one at the BMW showroom and was unimpressed with how quirky it all felt. The Q6 I tested at Audi seemed nicer in a more conventional way.
Each to their own of course.
