Was having a retro itch so I dug a few bits out of storage.
Pentium 3 Coppermine 1GHz with 768mb of RAM and a bunch of SCSI devices, used to be some kind of server.
Had 98 on it, installed fresh XP Pro.
Put a Rage Fury Pro 128 in it at first, but it was a bit too weak, so now it has a GeForce 2 MX in it.
Pretty good 'little' Half Life system now!
Also using my 21" Dell D1626HT which is a re-branded Sony Trinitron GDM-500PS, my Compaq MX11800 which is a re-branded Cherry with MX-Browns, and my LoFree Touch PBT mouse!
F-Zero was the only game which kinda needs the 1mm trick or to go via the fire slot to boot. Realistically the SNES cart slot is just a bit tired, and maybe if I decide to keep it I'll see if I can find a specialist to take a look/replace the cartridge slot, but I was genuinely glad to find every game basically worked.
. Whoops.
