- 20 Oct 2002
- Oxfordshire / Bucks
I do have premium
I do have premium
Finished it after work. No problems
Just need to test it
Always run through the Mod manager, not directly from Steam or it won't work. You can create a desktop shortcut that runs the modded version.
that is actually how i just did it
i was a prisoner ? lol no idea what or how, but anyway, looks great, but does not run very well at all, i think I will re do my game install
Look at videos from VR Dad. He gives easy guides on how to set it up and get great performance. It should run pretty well on your 5080. You just need to change a few settings in the performance tab in the mod manager. And enable DLSS in the settings. Not the Skyrim settings but the mod settings. You press the "end" key in game to configure it. Just watch the guide, it explains everything very clearly.
Perv.....I think because I downloaded the adult version (said it was the only version now?)
And i did not verify my age. So those parts may not be downloaded correctly causes issues. I will try the S F W version
Are you using OpenComposite and VDXR in Virtual Desktop? Gives a massive performance boost, though you lose the virtual keyboard.
I have no idea
Should be one of the optional mods in the FUS modlist. Turn on OpenComposite, and select VDXR in Virtual Desktop streamer.
I use H264+ on my Pro, at max bitrate as I find that gives the best quality. AV1 is an option on Q3.
download failed
Wabbajack was unable to source all files automatically.
Files will need to be put inside the downloads folder.
