Saving Sessions / Demand reduction thread
Question....can you donate the free hours anywhere?, I have 10 hours banked but no use for them, or very few of them as the weather changes this month.
Octopus saving session 6-7pm and then Axel event from 7.30-8.30pm. At least there's no clash this time!
Does anyone know the algorithm octopus uses to calculating how much you saved?
If it's a weekday, it's the previous 10 week days excluding saving session days (bank holidays are classed as weekends), it's not clear if it's official DFS days, or just ones Octopus participated in.
They then work out your average import over them days, and for the current session you have to import less, or export more than usual.
Can't remember weekends, but think they use previous 4 weekend days, not including session days.
Thanks - that's how I understood it but it doesn't work out for me.
I average about 25kwh per day - but make sure to use 0 during a savings session. That tells me I should have shifted over 1kw every saving session?
You can't really go by what you use in a day, as it's very likely the usage is uneven, but if you use zero during the saving session, that should be less presuming you usually use power in that hour.
Is just one or two sessions that are wrong, as Octopus had issues a few weeks back, my 15th September session shows that I shifted nothing, but I know I exported more than usual, other have had the same.
This used to be a good site, but due an Octopus problem it's not currently working.
As I said I use on average 25kwh per day - that's an average over quite a while :D
All my savings sessions show 0.25kwh savings which implies an average daily use of 6kwh?
But it's not daily, it's the hour the session falls in, you may use 25kWh in a day on average, but what is your normal usage between 6pm and 7pm (or whatever time the session is)?
How do you know you use 0 kWh between 6pm and 7pm?
Normal usage is 0. That's how I know
I have a big battery that runs the whole house between 5:30am and 11pm.
So, you have a big battery, running the whole house between 5:30am and 11pm, therefore no grid draw, and presumably no grid export (see caveat below), and I presume you are wondering why you're not getting happy hours???
FYI, I have a big battery (29 kWh), that runs the whole house 5:30am to 23:25, at 16:00 it starts exporting, to reach 15% SOC at 23:25 which is does dynamically monitoring house load, solar etc, which it does every day (except some winter days when it may run out due to the ASHP, but then it doesn't export either).
Along comes a saving session, said system now waits until the saving system starts, it then exports at circa 8 KW (full power), until the hour is up, then the system goes back to normal export mode. End result, I always export more in a saving session, than a normal hour in the evening, thus I always get happy hours.
PS. It very unlikely normal usage is zero, inverter outputs take a moment to react, that results in a slight grid draw, or export. I have a Victron Quattro and Cerbo GX running Node Red, and also Home Assistance monitoring everything so I know exactly what is going on.
I don't export yet (still waiting for all the bureaucracy to wind to a close). I do get happy hours every week.
If the calculation was based on that hour specifically, my average would as you say be zero. But I do get a quarter kwh of credit each time. That's the bit that doesn't make sense to me. I'd expect zero or close to 1 depending on the formula, which is why I asked.
In terms of how reactive my inverter is, according to Octopus billing my peak rate imports are around 0.02kwh per day. It's pretty snappy. I see no reason to expect my exports to be much bigger before I turn them on.
If you don’t import or export (outside of inverter noise) in the saving session you seem to qualify for the free hour.
My neighbour is on FIT so consumed every KWH generated and never exports their battery and always qualifies.
I wouldn’t worry about it.
I'm not worried :) I just like to know how things work.
