I've learned not to say timelines in publicOuch that poor doorhate it when things like that happen! Now the fun begins.... whats your timeline to get it complete? At least you have the nice new en-suite to fall back on
just asap.I can relate!I've learned not to say timelines in publicjust asap.
Pretty much every trade out there thenWho ever did that was a ****
You can run 50mm waste if that helps, combining two of the others.
Just for your own info, You are not meant to notch joists right up against the wall.
I would add support in that area to make good.
Considered going into it, but decided the lesser of two evils was dropping them down because there's a joist, a trimmer, and a nest of copper and cables there.Cant tell on the image but cant you run the pipe lower down where marked? Cant see whats in the way but joists appear to run the other way?
I had a look but couldn't figure out how I could get tools in, it's all solvent welded. Believe me I'd rather avoid mucking around in the room below so you've got me thinking again now.Ah a trimmer explains it. You could always change the fitting in the stack so you aren't limited by that 32mm.
