Pfffft, who cares about getting to your destination when you're having a good time?(the lyrics will be displayed instead of the nav...major oversight imo).
I've even bought a pair of BT mics so it's proper caraoke!Pfffft, who cares about getting to your destination when you're having a good time?![]()
Even funnier in the r5, it has the drive selector, the wiper stalk and then it has a 3rd stalk to control radio volume/station! Soon get used to it, though I do often reach for the centre console which is where my i5 one is!My Omoda has this too. Nothing says intuitive design like coasting in neutral towards a junction with a dirty windscreen.
I can provide visual clues if my insinuation isn't clear![]()
That said, might be a good shout for @MrRongCar
I would refer to those kind of passengers as pedestriansbut I don't use it unless I have passengers in the car and they want to use caraoke...lol.
You can remove the dash (lower part with the wood) to hide the wires when you do the permanent installJust temp installed hence the wire
I always have a dashcam in my cars and have been looking at having a front and rear fitted to my new ev but reading some horror stories with the 12V being drained. Anyone fitted one to a hyundai and kept parking mode or just binned off the parking mode and only use it when driving.
S3xy dash. Just temp installed hence the wire. I’ll post thoughts when I get to my destination.
That's a terrible view of the road, you might need a cushion.S3xy dash. Just temp installed hence the wire. I’ll post thoughts when I get to my destination.
Really like the dash. It integrates really well with the knob too - when you move the knob, it displays the available functions on the dash. Dead easy to operate without looking away from the road.
CarPlay works. No issues there at all.
Very configurable.
I love that it shows me blind-spot warnings in the corners at all times. Indicators also cause the edges to glow green.
It shows you tons of data. I like the gauge that shows how much bhp you are using at any time.
It just works. No messing about.
The best thing though is the Bluetooth commander box thing that you need to connect these to the car. I have it set to re-enable auto steer after changing lanes. Worked perfectly on my 200 mile drive today.
It's easy to mod, but tbh having a driver's display shouldn't have to be a mod in the first place!It's a shame all cars aren't that easy to mod, maybe the Tesla way is better, really basic add your own stuff.
100% agree.It's easy to mod, but tbh having a driver's display shouldn't have to be a mod in the first place!
