Solar panels and battery - any real world recommendations?
Yes he definitely did. It wasn't a typo.
8kw/h = 8kw per hour.
Ie having an 8kw inverter working at full pelt exporting.
Not 8kwh (kilowatt hours)...which is what will be exported if the 8kw inverter works for 1 hour...or a 3.6kw inverter for 2.2 hours...or a 800w micro inverter for 10 hours.
But I didn't state the time period or amount, I stated a rate (kw/h)
One is a rate of use, the other is the total amount used...the difference is there for the pedant :P
So yes, baby jesus did cry at your misguided pedantry.
Edit: for clarification I picked an obscene 8kw/h is because this will need a full g98/99 application when ron-ski's cheeky suggestion for a pv microinverter won't even require notification.
Or 16kW/30mins ? :) Remember a W is a joule/second already. So you can’t divide by time again otherwise it would be acceleration of power
Tbh you just say 8kW. That’s all the Dno care about whether it’s for 1 min or 3 days
Following my long post earlier. Any thoughts on comparison of 23kwh of battery over 11.5kwh.
Maths are £2k more so I guess the ROI on arbing is still pretty long.
It’s a coin toss really. How much will you miss the cash in the bank and what else could you do with that money?
If you are not expecting to change anything in the next 5-8 years, the extra battery may pack back but ultimately not add much benefit.
If you ever to get a heat pump (AC or air to water), maybe.
If it’s only for arbitration combined with agile export outside of peak generation then it could add some benefit. It’s a lot more risk when you are paying that much per kWh which you might not otherwise use.
Prices are high now but looking back to Feb, import and export rates were trending down at that point and had been for some time. In 2 years, prices could have dropped right back (again) and the ROI be negligible. They could stay high and you’ll be able to deploy your best Facebook smug face.
I’m not sure of the Fox software can handle agile fully automatically. Of not, you probably need something like Predbat to fully automate it also (locally via home assistant or £10/month via cloud). Managing it manually will get very boring very quickly.
Anyone else having issues with FoxESS Cloud this morning? About an hour ago I lost battery showing up, showed as offline and now my plant has disappeared totally and the web version is showing as "Under Maintenance", so I'm presuming it's them, not me :D
Just want to get some washing done & tumble dryer on, but not if it's pulling from the grid :D
It should work independent of the cloud. Have a look on the screen on the front of the inverter and you'll see if it's using the battery/solar.
Yeah I went out to the garage to check and could see the SoC and the +/- on the battery when it was charging/discharging.
I really need to get into Home Assistant to not rely on the cloud.
Yeah HA is great, I use node-red almost exclusively due to my setup, but for most things HA will do the job.
I wouldn't say the thread is a step by step guide but this is where YouTube is your friend.
AI can be 'okay' but in my experience it has been a bit hit and miss once you get outside of core functionality and you are trying to trouble shoot an issue with something fairly niche.
For me this is because stuff has been depreciated but still forms part of the training data, that was before it starts hallucinating solutions with yaml code which is non-functional or uses commands which never existed.
To be fair YouTube guidance can have similar issues as well and you need to watch something very recent because Home Assistant has done a lot of work recently to make it more 'noob' friendly.
Looking at:
Aiko Neostar 3S 475w solar panels, sigenergy sigenstor 10W phase 1 hybrid inverter, sigenergy 9.04kw battery.
Comes with 10yr warranty and reviews, like all solar panel systems it seems, are either great or moaning about crap service. Hopefully the warranty negates the service from sigenergy.
What are people's thoughts?
Which company did you go with for fitting? as i know you are local.
Install completed today so I now feel like a fully signed up member!
Question, can I log in to my Solis inverter and tinker with the settings if I’ve not had my handover yet?
Handover is due next week but I just want to make sure it’s set up so the battery doesn‘t discharge to the EV overnight.
Or are any settings changes something that should be left until the whole thing is signed off?
You need to create an account on Solis Cloud and pair the dongle on the inverter with that account. You can do both of these things in the app, you pair the dongle by scanning the QR code on the dongle (or box) and job jobbed. It takes 5 mins.
Hopefully they installed it in a way which means it blinded to your EV charger so that is not possible (assuming you asked for this).
Cheers for the advice and tips in this thread.
Gone for a 12 panel setup, 6 front and 6 back, FoxESS H1 (G2) inverter, FoxESS 5.76kWh battery, rosemary tiles, bird netting for a net price incl. scaffolding for rear. Net price £8,100. Seems very reasonable for greater London.
I went for as many panels as I could to future proof it, but kept the battery size small on the basis I could extend it in future if needed. Depends on use case I suppose, for me it works out fine.
Luckily all the 4 options I was quoted had a lot of detail in them, making it easier to do my ROI maths :)
First quote with the fox PQ kit. It’s got a freezer vibe though. Probably too wide for the alley down by the house. EcoFlow / Sig landing around £10k so this an easier entry at £8700
10 × Aiko Neostar 2S+
465W Dual Glass All Black ABC N-Type Mono solar panel
Fox ESS PQ1 5kW 1ph Stackable AIO inverter
1 × Fox ESS EQ5000-M 1x EQ5000-S battery module (9.86 kWh). Basically a master layer than up to 5 slaves stacked.
Looks like the Warm homes scheme as gone live today? Am i right. Even the sunsave guys have emailed today with the daft 20 year scheme now changed to a 10 year loan at 3.1% or a 3 year at 0%.
Is this ahead of the budget today I guess?
