What started as some NetFlow charts has turned into an interactive globe showing where my home network is talking to—and, where I can identify it, which applications are involved.
The setup is a UniFi UCG Fiber, a QNAP switch and Unraid. I initially collected sampled flows from the gateway, then moved capture and flow processing onto Unraid using a local switch mirror and a dedicated 10Gb NIC. Current capture is unsampled, with softflowd, GoFlow2 and InfluxDB behind the dashboard.
It now includes:
- Two visual styles: a modern globe and a colourful, 1980s WarGames-inspired display with cyan, amber and magenta. No scanlines!
- Live activity: animated connection arcs, traffic-weighted markers, hover details and graphical application badges where identification is supported.
- 24-hour history: scrub back through traffic, alongside throughput graphs taken from the gateway’s WAN counters.
- Gateway context: device names, application classifications and available CyberSecure information, gathered through API/SSH rather than browser scraping.
- Network intelligence: ASN, public BGP and PeeringDB context for investigating destinations.
- A country-test button: real requests to verified endpoints, staggered two seconds apart, shown as missile-style arcs. Countries without a verified endpoint are marked unavailable.
- Proper globe controls: country borders and names, closer zoom, optional overlays and a layout designed for a 5120 × 2160 fullscreen display.
There’s practical monitoring underneath the visuals too: capture drops, CPU, memory, latency and SABnzbd activity. Protective holds stop capture if Unraid comes under pressure.
The live activity layer refreshes every two seconds, although flow export still arrives in batches—it isn’t pretending to animate every packet. IP locations are approximate, and the arcs illustrate connections rather than measured physical routes.
It’s become a useful way to understand the network, with just enough NORAD control-room nostalgia to keep me staring at it. Definitely scratches that old network engineering itch.
