*** Official Ubiquiti Discussion Thread ***
You can use Wireless pre-shared keys and only have a single SSID, the password defines which network the client joins. I don't think it supports WiFi 6e/7, so in your case you'd have two SSIDs like I do, the main one, and one covering multiple other networks.
Yes I know, but that drops you to WPA2 only. Then the reason I have the separate 2.4G SSID is for devices that are WiFi 4.
Edit: You're also right, it doesn't support 6Ghz, only 2.4/5
The cost to add the option to the workflow will probably outweigh the cost saving from the 0.0001% of people who will take it up.
Not to mention that if you have any problems, the ISP will not want to know I tell you she their router connected because they can see telemetry from it but they can’t see telemetry from your router.
Yes I know there is Aquis but they are a niche ISP and not what ‘normal people’ use.
I'm with Idnet at the minute they also don't send you a router.
So as above, a little like a guest network where it restricts network access.
Yes pretty much, difference between guest and iot generally seems to be you allow interdevice communication on IOT where as you don't usually on a Guest one.
Then you say a rule to allow your main network to anywhere and allow established so your IOT can reply back but not instigate communication.
Like I said you can go as advanced as you like or keep it as basic as an ISP provided device.
And they have a tiny subscriber base, it’s so small it’s not even listed.
Zen has something like 0.4% of the U.K. subscriber base, Idnet will be smaller than this. It’s tiny, it’s not even niche, it’s niche of a niche.
85% of the subscriber base is with BT group brands, Sky, Virgin and Talk talk.
That guest-network comparison makes VLANs much easier to understand. The distinction between allowing IoT devices to communicate while blocking them from initiating connections to the main network is the useful bit.
What started as some NetFlow charts has turned into an interactive globe showing where my home network is talking to—and, where I can identify it, which applications are involved.
The setup is a UniFi UCG Fiber, a QNAP switch and Unraid. I initially collected sampled flows from the gateway, then moved capture and flow processing onto Unraid using a local switch mirror and a dedicated 10Gb NIC. Current capture is unsampled, with softflowd, GoFlow2 and InfluxDB behind the dashboard.
It now includes:
  • Two visual styles: a modern globe and a colourful, 1980s WarGames-inspired display with cyan, amber and magenta. No scanlines!
  • Live activity: animated connection arcs, traffic-weighted markers, hover details and graphical application badges where identification is supported.
  • 24-hour history: scrub back through traffic, alongside throughput graphs taken from the gateway’s WAN counters.
  • Gateway context: device names, application classifications and available CyberSecure information, gathered through API/SSH rather than browser scraping.
  • Network intelligence: ASN, public BGP and PeeringDB context for investigating destinations.
  • A country-test button: real requests to verified endpoints, staggered two seconds apart, shown as missile-style arcs. Countries without a verified endpoint are marked unavailable.
  • Proper globe controls: country borders and names, closer zoom, optional overlays and a layout designed for a 5120 × 2160 fullscreen display.
There’s practical monitoring underneath the visuals too: capture drops, CPU, memory, latency and SABnzbd activity. Protective holds stop capture if Unraid comes under pressure.
The live activity layer refreshes every two seconds, although flow export still arrives in batches—it isn’t pretending to animate every packet. IP locations are approximate, and the arcs illustrate connections rather than measured physical routes.
It’s become a useful way to understand the network, with just enough NORAD control-room nostalgia to keep me staring at it. Definitely scratches that old network engineering itch.
IQR6V3EYM5m2TYQuK7_UXOe6AWDjYsBT-s8cyyDqNPLMnAQ
It now includes:
Layer 2 - Go
Layer 3 - Go
WAN - Go!
Firewall - Go
We are a go for browsing YouTube!
:D
Only US-East so far, not too bad but if you are security conscious you might not want your data stored there. I'm also wondering what the encryption settings are, I'm guessing it's simply Backblaze managed, so files won't be encrypted by keys you control.
Also likely cheaper to just use Backblaze directly, rather then pay Ubiquiti for a little more simplicity.
Pretty negative I guess from me, but these things really should be made clearer to the consumer, especially when it comes to data privacy.
$6.95pm S2 or their "computer" solution is $8/9pm ("unlimited"); so Unifi Cloud doesn't seem too bad, although hopefully they open it up to BB's Amsterdam DC (and others).
Small question on access points.
I've currently got a U7 Outdoor Pro. I want to mount something on a covered terrace ceiling. The U7 Outdoor would work, but looks more like it should be wall mounted and would look a bit daft. Are the normal ceiling AP's ok being outside, assuming they're completely sheltered from rain. I'm in Spain so humidity shouldn't be too extreme either.
I do have "indoor" ceilings and fans and so not really sure why i'm worrying about an access point!
If you're in Spain and they can't be directly rained on then put normal ones outside, even if it does rain it's not going to be humid for very long
Doesn't Ubiquiti do in ceiling mounts for their FlexHD/Mesh (cylinder) AP's? Could be an option if they (still) do, you're happy to stick another hole in the ceiling and wanting an outdoor rated AP.
Edit - this is the mount (https://uk.store.ui.com/uk/en/products/flexhd-cm-3) which should achieve something like this (https://www.reddit.com/r/Ubiquiti/comments/140peyk/u6mesh_soffit_installation/).
I wouldn't be cutting large holes in a building to accommodate an Ubiquiti product, one of the most "changes their mind all the time" companies in existence
Hmmm the mesh mount would be an option as I’ve already got a U6 mesh device and not sure where to locate it.
The terrace ceiling is only plasterboard with a cavity under the concrete so any repairs would be easy.
I’m thinking the U7 Long Range though. Extending out from the terrace to the pool and beyond would be handy.
