Solar panels and battery - any real world recommendations?
Scaffolding went up today, and install is booked for Monday. Exciting times!
Anything I need to do regarding Octopus and moving tariff? We don't currently have an EV, although we're tempted to get a new Polestar 4 SUV which would be here early next year.
Get on the EV tariff once it’s installed.
EDF is cheaper so consider switching.
Same here scaffold up yesterday, so should be joining the club this week, if install goes well, not a hard core setup like some on here, only 4kw of panels :( only have a tiny roof due to velux windows etc, so solar is almost pointless but thought I would do it anyway, should do something in the summer at least and hope that MCS wall mounts come at some point as I have an entire side of the house that gets the sun all afternoon and could be pannelled no windows or anything there.
I went for a Tesla powerwall, is there any nuggets of info I need to know or confirm with installer to get that working well with a Zappi, I don't really want to drain the battery with my EV. I am sure it is in this thread somewhere but it is a big old thread.
You dont need a special solar EV charger really, you can simply charge the car overnight on the cheap rate then export the sun at 12p /13p
The industry seems to be all over the place in regards wall panels, I think it was K2 that specifically had a system (for commercial), but all you need is an MCS installer who is willing to do it.
The industry seems to be happy to skip many other parts of the technical requirements, such as loft smoke alarms at times so there should be no reason an installer wouldn't fit wall panels, you just need to find one who hasn't got work coming out of their ears doing bread and butter roof installs. (Good luck with that)
Because they are rarely used there are few certs in place, but a flat roof type system should work IMO, the issue is mainly around the angles to comply with legislation in regards gap from the wall.
The simplest way of having no solar dumping into charger is via making the solar system blind to it. As tamzzy says in effect.
You will be surprised how much 4kwp generates. The installer should have given you an illustration (probably low balled) as part of your quote.
Yup I am sure it will do something or I wouldn't have bothered but not too worried about payback more so allowing me to use more for AC etc in the summer.
Yup you point me to that wall stuff but I have not pursued it yet, I'll see how I get on with the basic package and do some decent monitoring of the sun on the wall to confirm my hypothesis, I am sure it be double the array of my roof, of course it won;t get the sun for as long a period but should expand the window to later in the day.
@reef so you decided to jump to Agile Outgoing as well then (from your post in the other thread), but you have the luxury of SigenEnergy which should do it all for you.
Not been paying attention but I think our Sigenergy battery hasn't been charging overnight (cheaper rate) for a while now. I remember in our early months, the battery having charge when I woke up but it hasn't done in recent months. I have TOU profile set up to charge between 2-5am, have also tried removing and re-adding it. Looks like AI is turned off. Any suggestions?
I use Sigenergy and use time control setting the only thing I can think of is there are a number of settings after you set the time like charge rates and SoC settings, if they are set to default maybe change the rates to say 6kWh and see if that helps. What I mean is maybe your default setting has been set wrong.
Mine looks like this…..
If it still does not work maybe set a 15min charge slot while you are around and see if you can see what it does.
At present prices it was a no-brainer. I've exported 24.0kWh today at an average of 26.66p/kWh. At the moment I'm just sending out at the highest point in the 4pm-7pm window and going down to 30-40% SOC depending on the day, but may set it up to be automated soon.
I should have used a five core cable, would have been easier/better but the electrician didn't mention that option, but I did get the 3 core cheap at an auction when a local electricians closed down.
When you say five core, you mean use 2 in one direction 2 in the other and a common earth?
With mine I would have the new grid supply come into the garage, through the fuse and into the meter……….then I assume it goes into the gateway, then the gateway would be connected to the distribution board as I do not want to move that, so think I would only need one cable.
On my Sigenergy gateway it's meter to gateway, then gateway to house.
Yes.
5 core is about 6mm larger in diameter than 3 core SWA, it would have been better than the two I have, they had to weave their way through the utility room and kitchen to get out to the garage.
Back in business. Battery was almost fully charged when I woke up. Now on...
Midnight-2am - self consumption
2-5am - charge
5am-4pm - self consumption
4-7pm - discharge
About to confirm my installation date and much to the opposite force of the quotes with Sigenergy im going with the EcoFlow Ocean 2 kit - battery more capacity, discharge higher and longer warranty.
Any care points ii may have overlooked? I dont like the plastic covers on sig, they never seem to align and the wall bracket looks more like something from a garden centre. Other than that its hard to differentiate.
Cost? How many kW? Battery only or Solar also?
Any care points ii may have overlooked? I dont like the plastic covers on sig, they never seem to align and the wall bracket looks more like something from a garden centre. Other than that it’s hard to differentiate.
Most systems are a much of a much ness in general. My only advice is to make sure your EV charger is blinded to your inverter.
Any EV charger can be integrated into the SIG system via its software but I’m not sure how easy that is on Ecoflow, if it’s even possible. It’s best to just blind it and not have to worry about it.
yeah, blinding is the optimal solution. if you really want to charge solar battery to EV battery, then just stick it on a granny charger via a wall socket.
