Dashcams!
I'm looking at a Viofo A329S/T, 2 or 3 channel version for my Kuga.
Just need to work out all the kit I need to hardwire it and how much of a faff it will be to cable manage it all under the trim/liner. Don't mind the buying, it's the fitting that puts me off as I want it neat and tidy. :D
@Gazanimal - I bought the A229 Ultra 3 channel to fit into a Polo, wasnt too difficult to cable manage , i was dreading it and kept putting it off, however was pleasantly surprised it wasn't as difficult as I thought it would be, and I'm fussy (OCD level) with it needing to be neat and hidden.
Came pretty much with all required , if you want parking mode too buy the hardwire kit.
Only advice I can give is if you want parking mode decide now/upfront as its easier to wire the hardwire kit now than retospectively as need to remove the power wiring that comes with the camera and rewire otherwise.
Yep I'd want the parking mode, so would definitely get the hardwire kit. Just trying to work out which fuse taps I need and also if I should get an extra battery pack to run the dashcam from, rather than draining the main car battery.
Good thing about the latest firmware on Viofo is you can geofence the parking mode with 3 different zones
It means you can tell it not to put on parking mode in upto 3 locations but, outside of these locations, parking mode activates.
I have it set.to my home and work locations as both have CCTV covering the car better than a dash cam will but, if I go to the shops, Parking Mode auto activates as it is outwith the GPS geofence zones
Works really well
edit: meant to say.. it took me about 30 mins to hardwire and install front and rear cameras... Much much easier than I thought it would be. Fuse Taps are the way to go :cool:
Battery is an option if you dont want to wire directly to the car or fusetap etc, and I believe Viofo have a specific dash cam battery with appropriate leads. I did look at getting the battery but its not readily available in the UK direct from Viofo. I think a couple of places sell it, or you can buy from Viofo.nl but its not cheap and not sure re warranty if buying from nl.
Again if you decide to go this route, buy battery and fit at same time, as the battery comes with specific power leads for the dashcam too, so you dont have to rewire.
Other option is using the ODB port connector, still uses car battery but saves hardwiring/fuse tap
Also buy a large flash card as I believe the A329s combines the video files into 1 , ie multistream in one file, so larger file sizes if i remember correctly
Either way good luck with whatever option you go for, you wont be disappointed though, they are pretty decent dashcams, I'm really happy with mine.
Looking to get the A329t-3ch with the telephoto camera.
Anyone know of any decent discount codes for the VioFo website? I know "Ashley" does 5%.
I think I'll stick with the hardwire version tbh, rather than the battery and look at which fuse I should use as some recommend ignition connected, whereas other say a permanent live (both have pros and cons due to battery drain or not)
Using the Viofo website for the majority of the dashcam and accessories is cheaper than BezosBay, especially with the discount code, but things like the SD card are cheaper on the rain forest so I might mix where I purchase things, but I hate the fact an SD card I bought 2 years ago that's tripled in price now. :D
Do you use the Viofo MicroSD or something like SanDisk Extreme which I use in my Drones?
I've always wanted a Dashcam but the Mrs has always said "What's the point?".
After watching Dashcam Justice on BBC1 (excellent series) I'm going to overrule her.
I've decided I don't want to spend a penny more than £200 for front & rear cams and my mate from Halfords will fit it.
So OCUK what do you think are the best models up to that price range?
Nextbase 522GW
One of the Road Angel's - if so which one, the one that fits over your mirror or standalaone?
What are the disadvantages of the mirror one?
Thanks
Really pleased with our RedTiger F77 - quality is outstanding (Front 4K, Rear 1440p), can install a hardwire kit so it also has parking monitor. I have a 256Gb SD card in ours.
My only gripe is the voice commands - if my kids say anything that sounds remotely like "Take a picture", it does...
Thanks for that however I'd like one off the link I gave because I can get a discount and get it fitted for very cheap.
He wouldn't install someone elses ?
I'd been looking at black friday deals on aliexpress where for £100 can get just a front camera, with usb plug connector for
~£100 with the similar good reputation sensor to redmoggs's
70mai Dash Cam A810S 4K HDR IMX678​
I'm not sure I can mount one on the back windscreen somewhere where the wiper wipes, so think that maybe a waste of time,
but front&back £40 more. Another reason against rear cam - it may interfere with dab radio antenna on the rear window.
Nextbase 522GW
Thanks
Reason why nextbases are so cheap compared to others? they are crap
i had a 522 and they lasted a week before giving me issues, load of bull
i got a blackvue , its been in 2 cars of mine (same one transferred over) 4 years now, and they are amazing, still going strong
I got one of these on an AliExpress special for £62. It's a pretty large camera compared to my previous dashcam, but I can recommend.
I have used front and rear Viofo A119 V3's for several years and they have been faultless. They have caught hit and run car park dings twice, both of which sailed through insurance after supplying the footage. Saved me thousands.
Looking further at the 70mai dashcam family: whilst it will take an emergency video if you have an accident/brake sharply
with footage starting from before the incident, it doesn't seem to have a mechanism to manually make such a before recording from voice control
or (distracting) buttons, like if you haven't had an accident and just want to record the scenery or accident not involving you,
so you have to be recording all of the time instead. - mai.
Capture Every Detail, Preserve the Full Story​
Evidence Before, During and After Every Incident.
Enhanced buffered emergency recording captures up to 190 ³ seconds before and 30 seconds after an impact, preserving the complete sequence of events. Emergency footage is automatically saved to a dedicated folder for quick access in the 70mai App.
3. The exact duration captured depends on the timing within the loop recording cycle and your selected loop length (configurable to 70s, 130s, or 190s).
Hi, I know you said not a penny more than £200 so forgive me, but the BlackVue SAFY9 would be worth paying the £29 extra for imo.
Just ordered it and it will be fitted on Dec 2nd.
My mate was going to fit it for £50 but I would have needed a £30 hardwire kit.
By the time I got other discounts it was easier to just let Halfords fit it and then it's all guaranteed etc.
Thanks for that @cadmunkey and in real life it's quite compact.
I've got the A119 mini 2 which I wired in myself to a USB C port in the front in my Kona EV. Did not use the hardware kit but I have used a power brick in parking mode which actually works quite well just to see what type of stuff it records. Not sure whether I would use it when its really hot but its worth thinking about because it lets you test parking mode or if you park your car in a slightly dodgy area or just to cover parking in a parking garage or supermarket. Never thought about sticking another A119 in the rear not sure why I didnt think of that before. Touch Wood never needed it but I have watched it a few times just to see the muppets who nearly drive into you. One downside with the A119 it takes an age to download video to your phone. By the time its finished I could have took the sd card out put it in my computer and downloaded the lot that way.
