The Manchesters will clock pretty high because of the lower amount of L2 cache to hold it back. And the Opterons will clock high because they run cool and tend to not need as much voltage with increased FSB to remain stable as 'normal' X2s.
The Toledos are the only ones which don't overclock particularly well, but even then, some of these have been very good.
If you can't get the memory to run at the speed you want it to, just stick a divider on it
Jon
Jon
