Choosing a Turbo...
28 Jan 2003
Devon
is so hard :(
I have a set goal in my head which is around 11.5sec 1/4's with terms around 125 which would make you think choosing a turbo is easy.
Nope.
Do I buy a all in one shizzle which SHOULD get me to my goal like the below kit, based on the GT3076r.
or do I over spec with say a GT35 and its extra lag but safe in the knowledge my mother could drive it to my goals?
Both my friends will be in the 11's so cant mess this up :o
one thing ive learn in life is that if there is something bigger/better, just get that one otherwise youll end up wonder "what if" and "shoulda/woulda/coulda"
even if you get the lag free turbo that will get the power, when you want to exceed that power, youll be wanting the other bigger turbo etc
Nicely put, never really thought of it like that :)
will have to think it over a bit more but leaning towards the 35r :D
Seriously, the 35r will be your best bet, because you can have the same power as with a smaller turbo, with room for more, as your car might not get the times you want with the power you're aiming at. So the best thing to do is to add more power, which can be easily done the the 35r. Buy it, fit it, tune it to a good medium, then if needed, turn up the boost. O and use N.O.S (filter blocked it??) as anti-lag if you're fussed about before the turbo comes in :)
Get the GT35R and some adjustable vernier pulleys and cams then you can play with the cam timing to reduce the lag.
Bigger turbo and some *** to sort out the lag. (why's n o s filtered?)
Because its to stop all the bay racer type talk AFAIK and because its a single brand.
It should really be refered to as NO2 not NO.S;)
Edit: You wouldnt use N'O2 to sort out lag, The best thing to use is an Anti lag System
NO2 not NO.S
Nitrous oxide is N2O, not NO2 (nitrogen dioxide) ;)
You can use nitrous oxide very effectively to prevent lag, as it increases peak torque at low to mid RPM - so whilst the turbo spools, the N20 compensates at low engine speeds until the turbos kicks in.
N2O also increases exhaust gas pressure and heat which can help spool the turbo faster.
Running N2O and a turbo simultaneously can gain you massive power increases provided the engine can handle it - but this can backfire as it can increase induction temperatures phenomenally so you have to have an excellent intercooler, or have a system in place to cut it off if it gets too hot (as you stand to loose performance, or increase the chances of detonation and wave bye-bye to your pistons!).
