- 18 Oct 2002
- between Blandford Street and Mars
That's one of the things I'm talking about above. If both units compressor map meets the requirements, the larger unit could introduce additional lag that is not desired so while, at first glance, the larger unit seems a better bet, the smaller unit may produce better results.
Conversley he may find that the larger unit has a freer flowing turbine, allowing a higher peak rpm where the smaller unit is beginning to impede the exhaust flow. Or indeed, maybe not.
