It's not cheaper if your buying of Overclockers ...
Leadtek GeForce 8800 GTS 640MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
£189.99
£223.24 inc VAT
That's the cheapest you can get out of either card as far as i can see.
I hear a lot of 2900XT owners complaining about power,temps and noise.Can someone please tell me what temps should I expect for the 640mb and the 2900XT(with stock coolers)?Would be an interesting comparison.I would also like to know what power each card needs,on idle and load.
I've got the side of the case off, and lots of fans.
not a practical option for some.
.So the case side open increases temps? cooled my CPU more.
It's ok for me I think, I took out some shelves at the right side of my desk and put the PC in there, so no side on, better temps, cant lose.
Increased dust, increased noise, looks amateurish, you lose.
ouch thats harsh, taking the side panel off is more like a last ditch effort/desperation attempt to keep temps down. i shoudl know i used to do that back in the old days.![]()
Maybe but if I needed to open my case to reduce temps then that project/system would be a failure.![]()
BTW, just like some of our Generators at work, some run cooler with doors open some need doors closed as of design, they suck air in rear and out front of radiator, they actually suck the doors shut if not locked open with the Stays.
PC cases are kind of the same, you can run it with no sides and fans on parts will cool them parts but actual Mobos parts etc will get hotter, they need a airflow from front to rear (normally), every little chip and mosfet gets airflow ideally, I image HDD runs cooler with sides on so air is going in over them at front of case not wasted out side and everywhere.
Again it all depends on your actual set up, I close case as of , airflow/Noise/Dust (use filters) and my set up runs cooler closed and its part of livingroom so has to be aesthetic.
I know my PC runs cooler with no side on, if you look in the case gallery you will see how crap my case is.
Well if you can afford to buy all that hardware in your sig then a new case and some fans should be no problem, it's just my opinion of course but to me having a case open is amateurish and displays a certain level of incompetence. But an open case does make more noise and attract dust, fact.
What you chatting ... its a common suggestion to keep temps down, i use to have to have the side of on my old computer or it all overheat and restart.
All this amateurish and incompetence stuff your talking about is a load crap tbh.
