Now I’m happy it’s got no leaks, I’ve powered it up. I’m really pleased with how it’s turned out. The LED ring on the Heatkiller tube is an Aquacomputer rgbpx one for their Ultitube reservoir, and is controlled by the D5 next. I modified the struts on the Heatkiller res by milling a slot so that it would accept the Aquacompter ring. The Watercool made strip to fit the Heatkiller is just a strip down one leg with a few LED’s on. I think the ring is a lot more even than that would be, and the fact that it only needs a short wire to link to the pump, rather than a long one right back to the motherboard makes it even better.
A brief spec off the top of my head if anybody is interested is:
MSI MEG Unify Z490 ATX
i7 10700K overclocked to 5.2 all core (although I have benchmarked at 5.3)
MSI Gaming X Trio RTX 2080
32gb G Skill Trident Z 3400mhz
2tb Adata XPG M.2
256gb Samsung 960 M.2
2x 2tb firecuda sshd
Be Quiet straight power 11 850w PSU (ATX sized!)
Custom braided cables
2x Aquacompter D5 Next
EK FLT 120
Watercool Heatkiller tube 200 D5 mount
Watercool Heatkiller D5 pump top
Watercool Heatkiller IV CPU block
EK Vector Trio GPU block
2x Alphacool XT45 280mm radiators
EK Coolstream classic 360
EK Coolstream classic 120
a mixture of Alphacool and Barrow fittings
3x Noctua NF-A12x25
1x Noctua NF-F12
4x Corsair ML 140
2x Aquacomputer Splitty 4
2x Phanteks neon strip 400mm, 1x 550mm
1x Phanteks halos lux
Various custom made panels, brackets, mounts and enclosures
A modified Lian Li 011D Mini
Now for a few more pics
Its not too bad in the back for space actually
![](https://live.staticflickr.com/65535/51040658181_45fe723356_c.jpg)
The splitty 4 mounted in the back of the case linked to the D5 Next to control the case fans
![](https://live.staticflickr.com/65535/51040760617_48ee783457_c.jpg)
And the rear of the external enclosure if anybody wanted to see it. Got another splitty 4 on here again
![](https://live.staticflickr.com/65535/51040751797_d37672aa46_c.jpg)
2tb Adata XPG M.2
EK FLT 120
3x Noctua NF-A12x25
1x Noctua NF-F12
4x Corsair ML 140
