£1000 gaming build help
4 Dec 2002
North Lincolnshire
Got around about £1000 to spend on a gaming PC but need everything apart from a mouse and keyboard + monitor.
Gonna buy a 22/24inch monitor after 2 weeks from now so I'm using my 40 inch TV in the mean time via HDMI, so a graphics card with HDMI would be useful lol.
Not bothered about fancy cases etc and I need windows 7 + dvd drive etc also.
Any ideas?
OcUK GeForce GTX 570 1280MB GDDR5 PCI-Express Graphics Card £259.99
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor with FREE Operation Flashpoint Red River Game £161.99
MSI P67A-GD65 Intel P67 (socket 1155) DDR3 Motherboard - (Sandybridge) ** B3 REVISION ** £132.00
NZXT Phantom Enthusiast Full Tower Case - Black £109.99
Corsair HX 750W ATX Modular SLI Compliant Power Supply (CMPSU-750HXUK) £109.98
Microsoft Windows 7 Home Premium 64-Bit - OEM (GFC-00599) £79.99
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) £46.99
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9) £39.98
Akasa AK-CCX-4002HP Venom CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/AM2/AM3) £38.99
Sony Optiarc AD-7260S 24x DVD±RW SATA ReWriter (Black) - OEM £15.59
(£12.99) £15.59
(£12.99)
Shipping : £13.75
Total : £1,012.00
Minus the shipping and it's under £1000. Look ok to you?
Wu
My attempt at something a little different (thumbnails are links):
You might want to grab a fan for the HR-02, but it should be able to run a 2600K in that case passively.
With this you've got 8GB RAM, a 128GB SSD (which should be big enough for Windows + Steam if you're careful. I have a similar set-up), plus the 2600K you wanted, and if you sell Red River, which is meant to be rubbish, you should be able to get it to £1200.
Having just seen the bank holiday deals, it might be worth getting one of these - excellent cooler and flashable to a 6970. Should be out next Wednesday too.
is 560gt SLI actually decent? Sorry for my rather daft question but those are one of a tiny fraction of graphics cards I know sod all about :S
Hi there.
Its non-refernce, dont think it can be flashed:)
Nicely living up to your name, yet again: Clicky
And if you couldn't be arsed to click the link, I'll give a run down:
-it has a dual BIOS switch
-the core is the thing that's different between the 6950 and 6970
-so therefore you use RBE to modify the stock BIOS to allow unlocked shaders, then flash this modified BIOS
As it says in the conclusion:
Techpowerup said:
•Can be modded to HD 6970
GTX560 SLI is impressive at that budget, though probably unnecessary at that resolution.
Hence the "dont think" bit in the sentance, instead of "i am 100% sure"
and you can never have to much power.
seriously tempted by the 560gti SLI build but is there anything major I need to know regarding how to setup SLI? Also they are preorder (both makes at a decent price) so I might have to wait a while :(
Are they much quicker than say a 580gtx? Will be gaming at 1920x1080p for the for-seable future due to the prices of 2560x1440+ monitors still being quite costly.
